Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 67
  1. Originally Posted by davexnet View Post
    If the script is not in the same folder as FFmpeg, you have to use a fully qualified file name in the call so the system can find it:
    ffmpeg.exe -i "c:\your_folder\script.avs"
    ffmpeg is in the same folder as the script, that's why I didn't add that path. I will try that to see if makes a difference, doubt it will. If it does I'll let you know.
    Mar 2008
    In that case drag the script to vdub (or vdub2) or AVSpmod to make sure the script is good
  3. Originally Posted by davexnet View Post
    Yep same error adding path.
    Yes the script opens up and displays the video OK. It's the pack Lollo set up for me (see his above post ad the link)
    Mar 2008
    Better wait for lollo, I don't see anything obviously wrong with it -
    your command line worked as-is except for the different source file:
    I:\bin32>ffmpeg.exe -i "C:\Users\davex\Desktop\college-a.avs" -c:v libx264 -crf 17 -preset slow -aspect 4:3 -c:a aac -b:a 128k outputff.mp4
    ffmpeg version 4.1.1 Copyright (c) 2000-2019 the FFmpeg developers
      built with gcc 8.2.1 (GCC) 20190212
      configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth
      libavutil      56. 22.100 / 56. 22.100
      libavcodec     58. 35.100 / 58. 35.100
      libavformat    58. 20.100 / 58. 20.100
      libavdevice    58.  5.100 / 58.  5.100
      libavfilter     7. 40.101 /  7. 40.101
      libswscale      5.  3.100 /  5.  3.100
      libswresample   3.  3.100 /  3.  3.100
      libpostproc    55.  3.100 / 55.  3.100
    Input #0, avisynth, from 'C:\Users\davex\Desktop\college-a.avs':
      Duration: 00:02:20.37, start: 0.000000, bitrate: 0 kb/s
        Stream #0:0: Video: rawvideo (Y42B / 0x42323459), yuv422p, 720x480, 29.97 fps, 29.97 tbr, 29.97 tbn, 29.97 tbc
  5. Make sure the bit-ness of ffmpeg and AviSynth match. Ie, 32 bit ffmpeg requires 32 bit AviSynth(+), 64 bit ffmpeg requires 64 bit AviSynth(+).
  6. Originally Posted by davexnet View Post
    He had the script setup for source I uploaded S1E2 (PAL) 25i.mpg though not sure what all that NTSC stuff is about? Guess could try my NTSC source as well.
    Hmm I downloaded the latest ffmpeg from here didn't see any 64 or 32 option. That could be it, pretty sure Lollo said this was 32bit. Thanks I'll check that too.
  7. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Check 32-bit vs 64-bit mismatch, as jagabo said
    In the avisynth script eventually use full path for avisynth plugin directory:
    plugins_dir="C:\lollo files\QTGMC\AviSynth_plugin_dir\"
    Mar 2008
    Very good point. Earlier, I had tried to load a script containing mpeg2source with 64 bit ffmpeg.
    But I got a specific message about being unable to load a 32 bit dll
    Assuming Avisynth Plus is installed, both32 and 64 bit versions should be available and the bitness of ffmpeg
    (As jagabo mentioned) will determine which is used
  9. OK I installed AviSynthPlus_3.7.3_20230715_vcredist.exe as all I had installed was AviSynth_260.exe. Now I am getting the bit match error.
    [avisynth @ 00000254e80b8980] Cannot load a 32 bit DLL in 64 bit Avisynth: 'C:/lollo files/QTGMC/AviSynth_plugin_dir/masktools2_v2.2.30/x86/masktools2.dll'.
    (script.avs, line 10)
    [in#0 @ 00000254e8080f40] Error opening input: Unknown error occurred
    Error opening input file script.avs.
    Error opening input files: Unknown error occurred
    I can't find a 32 ffmpeg, everywhere I look it's 64bit version.
    Mar 2008
    Did lollo set up his scripts/plugins with 32-bit usage in mind? Best wait for his input
  11. Originally Posted by davexnet View Post
    No idea, yea see what he says.
  12. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    The package was for AviSynth 2.60 32-bit.
    Better re-read original post and restart from scratch
  13. Originally Posted by TubeBar View Post
    You dont need a 32 bit ffmpeg, but the correct 64 bit plugins in the plugins64+ folder of avisynth+
    Unzip and copy all into your plugins64+ folder.
  14. Originally Posted by lollo View Post
    I did and all the same result. However, I managed a work around (though not ideal).
    Your script works fine but I hit that snag w/ ffmpeg:
    ffmpeg.exe -i script.avs -c:v libx264 -crf 17 -preset slow -aspect 4:3 -c:a aac -b:a 128k output.mp4
    However once I load your script into Virtual Dub I can save the RAW AVI. Later I will need to remux that. It works just not ffmpeg part which I given up on.
    I can crop and process, remux the video later it's not terrible.
  15. ffmpeg should have no problems with AviSynth scripts. But like with VirtualDub you will need a 32 bit version of ffmpeg to use 32 bit AviSynth, a 64 bit version of ffmpeg to use 64 bit AviSynth. I don't think they make 32 bit versions of ffmpeg anymore.
  16. Originally Posted by jagabo View Post
    Right. They don't seem to. Lollo's script is setup for 32bit. I haven't tried to see if it works w/ 64 guess I can do that later. Regardless this looks like it will take a lot of time either way I do it. RAW takes up a huge amount of space
  17. Originally Posted by TubeBar View Post
    It will work but you'll have to track down 64 bit versions of all the required filters.
  18. Originally Posted by jagabo View Post
    ah...ok I'll see what I can do thanks.
  19. Originally Posted by jagabo View Post
    How do I try an NTSC file using Lollo's script? What you suggested TFM().TDecimate()?
    His script is:
    # plugins directory
    plugins_dir="AviSynth_plugin_dir\"
    	# QTGMC
    Import(plugins_dir + "QTGMC.avsi")
    	# Zs_RF_Shared
    Import(plugins_dir + "Zs_RF_Shared.avsi")
    	# MaskTools2
    loadPlugin(plugins_dir + "masktools2_v2.2.30\x86\masktools2.dll")
    	# RgTools
    loadPlugin(plugins_dir + "RgTools-v1.2\x86\RgTools.dll")
    	# MVTools
    loadPlugin(plugins_dir + "mvtools-2.7.45-with-depans20210608\x86\mvtools2.dll")
    	# Nnedi3
    loadPlugin(plugins_dir + "NNEDI3_v0_9_4_62\x86\Release_W7\nnedi3.dll")
    	# FFTW
    loadPlugin(plugins_dir + "LoadDLL10\LoadDLL\LoadDLL32.dll")
    loadDll(plugins_dir + "fftw-3.3.5-dll32\libfftw3f-3.dll")
    	# Srestore
    Import(plugins_dir + "Srestore\Srestore.avsi")
    loadPlugin(plugins_dir + "GRunT-v1.02\x86\grunt.dll")
    	# FFmpegSource
    loadPlugin(plugins_dir + "ffms2-2.40-msvc\x86\ffms2.dll")
    video_org=FFmpegSource2("S1E2 (PAL) 25i.mpg")
    video_restored=video_org.AssumeTFF().QTGMC().Srestore()
    return(video_restored)
  20. If you have the TIVTC filters autoloading your script can be as simple as:
    FFmpegSource2("filename.ext")
    TFM()
    TDecimate()
  21. Originally Posted by jagabo View Post
    TFM()
    TDecimate()
    Not sure as I didn't change anything. How do I enable the filters to autoload? Not even sure I have them as all I downloaded was QTGMC.zip and nothing in there for that. Do I need to download the script?
  22. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    You need to download the TIVTC package, containing TFM and TDecimate https://avisynth.nl/index.php/TIVTC
  23. Originally Posted by lollo View Post
    Link is broken, I get a 404 I did google it but couldn;t find the files.
  24. Originally Posted by TubeBar View Post
    Put the DLL or AVSI files in AviSynth's plugins folder. For 64 bit AviSynth that's the plugins64+ folder within the AviSynth+ folder. Use TIVTC.dll from the x64 folder of the archive:
    C:\Program Files (x86)\AviSynth+\plugins64+\TIVTC.dll
    64 bit AviSynth+ will automatically load all plugins and AVSI files located in that folder.
  25. Originally Posted by jagabo View Post
    OK did that but when I run the scrip:
    TFM()
    TDecimate()
    Some error in line 1 there is no function named FFmpegSource2. I don;t care about ffmpeg, RAW works fine in Virtualdub. So how do I load it in VD and go that route? It's easier.
  26. Member
    Mar 2008
    For FFMpegsource , ffms2,dll, ffms2.lib, ffmsindex.exe and ffms2.avsi should be copied to the plugins folder of Avisynth
    Be aware of the bitness, 32 bit files into the 32 bit plugins folder.
    Try this version
  27. Nevermind, davexnet already posted.
  28. Originally Posted by davexnet View Post
    Try this version
    BIG thanks davexnet, that worked like a charm
