Hi all, first post here in the forums. I recorded some family videos on vhs-c many years ago. I used a combo vhs/dvd player to record the vhs-c video on mostly HP DVD-R blank media. The new DVD-R discs will play in the DVD/VHS player that I burned them on. However, I would like to transfer the video on the DVD-R discs to my computer and then onto the cloud for safe storage.
The problem is the discs are not recognized by the dvd drive in the computer. I bought a new external dvd drive as an added test and that does not work either. The drives do recognize a "desktop.ini" file but none of the video files.
I also tried to finalize one of the discs in the dvd/vhs player thinking that maybe these discs were never finalized in the player. It seemed to be working but then the process failed and now the player and the drives do not recognize the disc any longer.
I tried using Nero Video module, and it said video not supported. Tried Nero Recode and couldn't find video files. Nero Rescue Agent didn't work either. I was recommended to use ISOBuster and it did find the video files but it wants me to pay $59.95 for a license key. I'm trying to find a free solution.
Any suggestions or pathway forward from this community?
Results 1 to 20 of 20
Yes, just give it a destination folder, hit start, and it will create an iso file
try with VLC media player - https://www.videohelp.com/software/VLC-media-player
see if it'll recognize the discs. -
VLC was the first media player I tried. Then winamp, and then windows media player. None of them worked.
Have you looked at this? I can't vouch for it, never tried it, but came upon it browsing the interwebs
https://recoverytoolbox.com/cd.html -
if you still have ISOBuster installed, see here post #4 - https://forum.videohelp.com/threads/288291-Rip-Video-from-un-finalized-DVD-on-my-PC-HELP%21#1839247 and this thread - https://forum.videohelp.com/threads/289047-faulty-DVD-R-will-not-finalize post #11 & #20
if you still have ISOBuster installed, see here post #4 - https://forum.videohelp.com/threads/288291-Rip-Video-from-un-finalized-DVD-on-my-PC-HELP%21#1839247 and this thread - https://forum.videohelp.com/threads/289047-faulty-DVD-R-will-not-finalize post #11 & #20[/QUOTE]
Thank you for pointing me to those posts. I will check them out today when I get some time.
Update: I tried another attempt at using the standalone combo dvd/vhs player to finalize a disc. This time it completed successfully and I was able to verify and test it in my external drive on the PC. I have now done about 20 of them and I'm having about an 80% success rate. I will probably just burn the original vhs-c tapes onto DVD again for the failed ones. Overall, I will have about 6 or so DVD's to reburn. On a couple of the failures to finalize, the process counted down from about 3.5 minutes all the way down to zero and never gave any indication that it completed the process. Just seemed like it froze or something. Kind of strange.
Just flashed a new blu-ray drive and now the disc tray won't open
By xEnchantedx in forum DVD & Blu-ray WritersReplies: 12Last Post: 6th Jun 2023, 23:34 -
New Win 10 laptop w/optical drive under $400?
By stargatesuite in forum ComputerReplies: 11Last Post: 10th May 2020, 16:03 -
DVD's not playing on more than one laptop
By Daveridge in forum DVD & Blu-ray RecordersReplies: 9Last Post: 27th Apr 2020, 11:26 -
Ripping HD DVD Disc to a HD DVD Blank
By Mr. E in forum Newbie / General discussionsReplies: 1Last Post: 10th Apr 2020, 08:12 -
Connecting Laptop to Laptop through USB
By dfisher052 in forum Newbie / General discussionsReplies: 14Last Post: 10th Sep 2018, 05:23
