On a Win10 Pro x64 desktop, I play a video in PotPlayer. Audio and video are out of sync. I import that video into Adobe Premiere Elements 2020. Audio and video continue to be out of sync in PotPlayer - but they are in sync, for the same video, in Premiere Elements. I close Premiere Elements and PotPlayer, and then try again to play that video in PotPlayer. Now audio and video are in sync.
I close PotPlayer and do other stuff for a few hours. I resume playing the video where I left off, in PotPlayer. Audio and video are back out of sync. I start Premiere Elements and play a bit of the video. It's in sync. I start a new session of PotPlayer. As before, the video is in sync there too.
Any idea what's going on?
In response to that request for an excerpt, I screen-captured a video segment using OBS Studio. Viewed in PotPlayer, it was out of sync. I cut a 30-second excerpt as requested, using Avidemux and also FFmpeg. In both cases, played in PotPlayer, the audio and video were in sync in the excerpt. I closed the first PotPlayer session (displaying the original) and started a new one (again displaying the original). Now the original was in sync too.
I have uploaded the 30-second excerpt as requested. I doubt there's anything of interest there.
There doesn't appear to be an issue with the video per se. It seems more likely that it would be a driver issue. It appears that tools like Avidemux may load drivers that resolve something missing in PotPlayer.
I think I did encounter the same problem when using other players. I can't test that now, because apparently the required driver is loaded at the moment. I will have to try again later, when the problem recurs in PotPlayer. -
But in that case, why would it be in sync sometimes and not at other times?
Probably not overwhelmed. The CPU is an Intel Core i7-4790. 32GB RAM. It's a capable video editing machine. System Monitor (via Moo0) reports plenty of free resources. Not much else running on the system. -
Maybe a Potplayer issue...
Could be a problem with temporary files too.
https://4ddig.tenorshare.com/windows-recovery-solutions/how-to-delete-temporary-files-...indows-10.html
Audio and Video sync issues with both Constant and Variable Frame Rate
By atomicBRblaster in forum Video ConversionReplies: 6Last Post: 12th Apr 2023, 14:29 -
Variable audio/video sync issues between operating systems?
By chconnor in forum Software PlayingReplies: 0Last Post: 12th Dec 2020, 00:32 -
Sync audio and video problem
By yocarim in forum DVB / IPTVReplies: 0Last Post: 26th Mar 2020, 03:36 -
Audio/Video Sync Problem
By southleft in forum Software PlayingReplies: 1Last Post: 12th Nov 2019, 22:01 -
Audio sync problem — video goes out of sync after a while
By maxalfreeman in forum AudioReplies: 4Last Post: 12th Sep 2019, 13:07
