It was just to show to Eric-jan that S-VHS versus VHS sometimes is not that big difference, because he hoped to be "party pooper" about my captures using that argumentEr... so you comparing not just workflows, but two different sources. Not fair![]()
Results 31 to 35 of 35
Still, your experiment is flawed and does not prove much. If it proved that SVHS was better, then, duh! If it proved that SVHS was about the same as VHS, then maybe your workflow is suspect
The source are different, using s-vhs does not improve that much in that specific case, the overall initial goal of Eric-jan was to prove that my captures are good only because they are S-VHS, which is false. Just as simple as that -
This "test" proves nothing.
VCR buying guide (S-VHS / D-VHS / Professional)
By lordsmurf in forum RestorationReplies: 326Last Post: 2nd Sep 2025, 05:10 -
Uprgading VHS capturing hardware
By Legge in forum Capturing and VCRReplies: 8Last Post: 23rd Jun 2023, 00:09 -
Capturing SVHS using a standard VHS VCR - Is it possible?
By DJ Kris in forum Capturing and VCRReplies: 15Last Post: 4th Jul 2020, 12:00 -
Questions about best vcr just for watching vhs tapes. (not capturing)
By streetsofrage47 in forum Newbie / General discussionsReplies: 10Last Post: 12th Nov 2019, 17:55 -
What's the best Capture Card/Software combo for capturing modern hardware?
By fsquared in forum Capturing and VCRReplies: 13Last Post: 13th Oct 2019, 07:53
