Hello ,
What will be the basic combination of digital video?
I researched this topic but results were confusing
I wanna convert some videos to very basic codecs without quality loss or minimum.
I know .wav format for audio which used in many feature phones for sound recorder
And .avi format for video
Am new to video encoding so I wanna start encoding from basics.
Also suggest any user-friendly video encoder for android and windows.
In other codecs there are many options to be set before conversion ,those options are for compression probably,and i dont know how they will affect my video quality..that's why need some simplest codecs to work with
Take the easiest way, use clever FFmpeg-GUI.
Load the video, click main, click encode video stream, click keep size, select CRF 18, leave all settings as they are and click encode.
[Attachment 72440 - Click to enlarge]
When that is done, click multiplex, the newly created video stream (in green) is already selected, also select the audio stream(s) and any subtitle streams, select mkv as container and click multiplex.
[Attachment 72441 - Click to enlarge]
When that is finished, you will find your new video in the Output folder. -
In Handbrake I suggest you start with Format mp4, h.264 (x264) video with Constant Quality 18 or less (lower is higher quality, bigger files) with Encoder Quality Slow or slower. Audio should be aac or passthrough (keep original audio).
Btw why everyone uses ffmpeg or handbrake for encoding purposes ,is there no other encoding softwares available?
I saw that some other encoding softwares depends on ffmpeg ,why is that?
Does ffmpeg or handbrake makes encoding libraries?like h264,h265 ,aac ,wav
or companies make them? -
No multiplexing will not effect audio sync, it's just a repack. ffmpeg has been around for many years, is open source (100% free) and thus anyone can use it. Not to mention it's a very powerful application that matches and even surpasses many commercial programs. You can do just about anything (low level) w/ ffmpeg.
Sure there are other applications non-ffmpeg that are commercial but not free and have a big leaning curve like Adobe Premier Pro/After Effects or FCP and Apple Compressor.
For your needs doing it fast and simple stick w/ what was already suggested. I like handbrake as it's super easy a monkey can figure it out -
Best video encoder for android?
currently I don't have any personal computer or laptop
Looking for suggestions
By shark_bloody in forum RestorationReplies: 5Last Post: 9th Sep 2022, 18:01 -
Suggestions regarding MCTemporalDenoise
By ZetaStax in forum RestorationReplies: 1Last Post: 14th Jul 2020, 15:03 -
Need suggestions on best encoder
By mjr0483 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jul 2020, 19:28 -
VPN suggestions?
By SyncroScales in forum Video Streaming DownloadingReplies: 13Last Post: 24th Nov 2018, 10:58 -
Tripod Suggestions
By chris319 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Sep 2018, 02:28
