I have a few (legal) mpg files where MediaInfo says they are 23.976 with 2:3 Pulldown.
Being in PAL country, I'm not sure what to do with them to make them 29.976 progressive h.264.
Can it be done with ffmpeg, and if so then how ?
Code:Sampled_Width : 720 Sampled_Height : 480 Pixel aspect ratio : 1.185 Display aspect ratio : 1.778 Display aspect ratio : 16:9 Frame rate : 23.976 Frame rate : 23.976 (24000/1001) FPS FrameRate_Num : 24000 FrameRate_Den : 1001 Frame count : 2 Resolution : 8 Resolution : 8 bits Colorimetry : 4:2:0 Color space : YUV Chroma subsampling : 4:2:0 Chroma subsampling : 4:2:0 Bit depth : 8 Bit depth : 8 bits Scan type : Progressive Scan type : Progressive Scan order : 2:3 Pulldown Scan order : 2:3 Pulldown Interlacement : PPF
Results 1 to 26 of 26
Don't apply the pulldown (or apply the pulldown then IVTC) and speed video (and audio) from 23.976 fps to 25 fps.
That's a progressive video slowed down to 23.976. The pulldown is just a flag that is optionally used when outputting 480i which is 29.97 interlaced. No need to do anything treat it as progressive and ignore the pulldown it's just a flag in NTSC DVD specs. If you apply the pulldown then you have 480i video and need to deinterlace, it's pointless and degrades the quality. I'd encode the video at 24fps (correct film speed) or leave it as 23.976 progressive.
OK, I'll try that, leave it as 23.976 progressive.
Of interest, I now see 2:3 pulldown and its interlacing is described under "2:3" here https://en.wikipedia.org/wiki/Three-two_pull_down -
Yeah that's the side effect of NTSC
Film is 24fps so for PAL they just speed it up to 25fps, the side effect is running 4% to fast and pitch being off. NTSC is another beast w/ the nasty pulldown causing judder and to the trained eye it looks pretty bad. Fortunately your video is not interlaced and does not contain a hard coded (baked in) pulldown. In that case you need to deinterlace PLUS remove the pulldown.
23.98 and 24.00 are valid frame rates for HD ready devices in 50 Hz land.
Ah, you have 480p. How do you want to watch them though? I thought that hardware media players don't care, and just convert to 50 Hz or 60 Hz on output. -
They don't and format wise there is no reason to convert unless he can't stream MPEG2 (like AppleTV and Itunes is noted for) and needs to convert to h264, or wants to shrink the size of the file down. Personally since I use AppleTV I have to convert everything to h264 but most people should not have to.
ok ta.
filesize counts in this instance, so h.264 @ 23.976 works for me -
Keep in mind that 23.976 fps video displayed on a 50 Hz display will usually deliver two little jerks every second. Or at 60 Hz, 2:3 duplicate judder.
Since you are re-encoding anyway and based on what jagabo said I'd do h264 @ 24fps. Film speed is 100% correct at 24 anyway, only reason for 23.98 is for NTSC interlaced playback which you don't need or want and trust me you don't want to deal w/ Judder.
Personally I usually encode ALL films at 24fps since it's the correct speed and I am re-encoding anyway, not sure 23.976 matters for me since I am in NTSC land but it technically it is not the correct speed that's all I know. -
Judder will be about the same for 24.000 fps and 23.976 fps videos on 59.94 and 60 Hz displays. The advantage of encoding at 23.976 fps is that he can use the original audio.
True, didn't think about audio as no need to re-encode that.
A bit off topic but many times I wind up w/ say iTunes or Amazon downloaded files already heavy compressed w/ h264.I hate the speed issue when it's 25 (23.976 I just leave alone). Forget about incorrectly encoded 29.97p files that's a mess I don't know how to fix or what moron does those. Regardless is there a tool or editor to simple change the speed w/o re-encoding? Isn't speed pretty much variable anyway and a flag more or less?
The audio I know I'd have to re-encode but it's a small price to pay for me. -
When from film sources those usually go through 3:2 pulldown to 29.97 interlaced frames per second analog video, then captured and deinterlaced to 29.97 progressive digital frames per second. The result is usually a duplicate every 5th frame, or two blended frames out of every 5. The former can be decimated back to 23.976 fps film frames, usually pretty cleanly. The latter can be deblended back to 23.976 film frames, but not as cleanly. Of course everything on youtube is overcompressed and having to filter and reencode again may further degrade the video.
I have some content (mainly cartoons) by HB (i.e. original Smurfs series) I bought from iTunes. We know those were made on film but yet WB has them encoded as 29.97 Progressive. How can you fix that? I think some Spongebob are too I have, maybe Spongebob was done at 30 but kind of doubt it. It's incorrect encoding.
My guess is the masters are 29.97 Interlaced 720x480 and whoever is doing the iTunes mp4 encode is setting the output as 29.97 progressive. I can do that in compressor too and results are the same. Bunch of dupplicate frames but nothing is flagged as interlaced, so how could you detect and fix that?
Forget YouTube that's a transcoded mess. -
Oh I have an Anime movie, the US DVD again is 29.97 Progressive. The BD was fixed to be 23.976 but again how can you fix erroneous encoding like that? You really can't that I know of.
To remove those with 1 duplicate in every 5 frames you just TDecimate. Those that are blend deinterlaced can be deblended with filters like FixBlendIVTC.
I wish this forum had a thumbs-up function on posts, I'd be clicking it a few times along the way to denote thanks.
Yeah we do need that, be nice to add that feature. You learn a lot on here, lots of helpful people who are experts w/ video. I remember when they started as VCDhelp lol I've been coming here that long...time flies. Back then when DVD-R were expensive everyone wanted to convert them to VCD, uh what terrible format I always hated it (VHS looks better).
I still have circa 200 30yo VHS-C cassettes of family starting and growing up, to convert (to DVD).
I ended up buying a cheapie VHS/DVD player which had a VHS-to-DVD recorder built in; press a couple of buttons and off it goes to record a tape to DVD; now to find the motivation ...
Resulting DVD quality is reasonably low, however "good enough" as value-for-money and value-for-time given the source and how many times we would watch it (probably once or twice in a lifetime). -
I have heaps of VHS circa 80's and 90's still not transferred
Not to mention lots of cool retro commercials etc. TV recordings. I don't have the time and motivation to do it quite yet. I'm kind of a perfectionist and want best quality. Every time I start to read up on it, I get depressed and move onto other things.
As for fam stuff, true probably never watch it lol
A friend of mine transferred some tapes for me a few years back w/ one of those VHS to DVD recorders. It didn't look bad basically looked like unmastered VHS which I guess there is only so much you can get out of those tapes. Esp the ones recorded on slow 6 hour EP speed to save tape, terrible quality! lol
PAL to NTSC using pulldown excessive judder
By mistateo in forum Video ConversionReplies: 75Last Post: 18th Jun 2022, 01:44 -
Problem converting PAL to Ntsc (pulldown or blends)
By spiritgumm in forum Video ConversionReplies: 31Last Post: 6th Feb 2021, 22:17 -
59.940 to 23.976, mixed progressive and interlaced?
By amaipaipai in forum Newbie / General discussionsReplies: 13Last Post: 23rd Jun 2019, 19:00 -
Ultimate Guide for Interlaced (29,97 fps) to Progressive (23,976/59,94 fps)
By kalemvar1 in forum Video ConversionReplies: 9Last Post: 22nd Dec 2018, 06:49 -
How to remove blended frames from NTSC 29.976?
By midts in forum Video ConversionReplies: 2Last Post: 15th Aug 2018, 12:07
