AIMP ver 3.6, according to several pages I've read, is supposed to have 5.1 surround capability and support for AC3/DTS. However, I cannot get it to output surround. I've tried both a 5.1 AC3 file and a 5.1 DTS file. Yet, these same files (and hundreds of videos with 5.1) output over SPDIF and play correctly on my 5.1 surround system using other software (e.g. MPC-HC, MPC-BE, VLC, etc.) I've set AIMP to Direct Sound with 5.1 Output trying its Windows Default option, and the 2 SPDIF Direct Sound options it shows. None of them will actually output AC3 or DTS. I know I could just play the files with MPC but since this is an audio-only file, I prefer to keep it in my music folder and automatically play it along with the rest of my music using AIMP. So... anyone know how to get AIMP to output AC3 and DTS? Thanks!
Why not use the latest version?
Because I have 3.6 using a customized skin that won't work with the current version. Regardless, as I pointed out in the OP, version 3.6 is supposed to support 5.1 surround sound. But, if you can provide instructions for making Aimp 5 play an AC3 file and actually send the proper signal over SPDIF to play it in 5.1 then I'm happy to obtain that info since I tested the portable version of latest Aimp 5 and it's not playing it properly either. Again, as pointed out in the OP, MPC and other software does play the file properly so it's definitely an AIMP issue.
E-AC3 to AC3 conversion using ffmpeg
By Nico Darko in forum AudioReplies: 31Last Post: 14th Oct 2025, 22:33 -
Convert DTS to AC3/E-AC3
By craigyy in forum AudioReplies: 5Last Post: 23rd Jan 2021, 08:20 -
Keep core AC3 track or encode TrueHD to E-AC3?
By slap_monster in forum AudioReplies: 1Last Post: 4th Dec 2020, 10:45 -
Is Aften AC3 superior to ffmpeg AC3?
By stonesfan187 in forum AudioReplies: 3Last Post: 2nd Oct 2020, 21:17 -
Is AC3 limited to 20 kHz? Is Spek limited at 20 kHz on AC3?
By MLP in forum AudioReplies: 16Last Post: 27th Apr 2020, 11:51
