Page 2 of 2
FirstFirst 1 2
Results 31 to 36 of 36
  1. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    There has not been made any solid state device to convert/capture VHS video signals
  2. Member Cornucopia's Avatar
    Wow, then all those years that I was hooking things up, creating files, and charging people money for 1000s of convert/capture from VHS was really all in my mind?!!
  3. Banned
    Nov 2022
    Originally Posted by lollo View Post
    Analog is analog, and no VCR can refer to Rec.601 specification. It plays a role only when you digitize the signal.
    True, but some analog formats are more compatible with Rec. 601 that other.
    For example, color-under used composite or at best Y/C, and the bandwidth of C is, what? about one eighth of Y.
    Betacam used (Y, R-Y, B-Y) components with Y having how much? 4 MHz for Y and 1.5 MHz for C.
    MII had 4.5 MHz for Y, 1.5 MHz for C. So, CAV formats mapped into Rec. 601 much nicer and became a proper stopgap technology during transition from analog to digital.
    I am not arguing with you, just adding
  4. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    You, we all, are trying hard to make something with the means that are available, by experience one learns, not all people have the same means available, but also do their best, i still think any computer system is a big hurdle to take, to make a good capture, with any (consumer) capture device, a lot of (correct) settings and knowledge are needed, when doing everything yourself.
    Prosumer devices may have allready the correct settings, or make it easy to choose from, doing the right thing.
  5. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    When I said we where losing our time…
  6. mr. Eric-jan's Avatar
    Apr 2018
    Netherlands
    That's what everybody does, unless you can stop time,
