Hi everyone, I apologise in advance if I have posted to the wrong thread.
I've been shooting amateur cine films and video since 1980, have always prided myself on backing everything up on tape, data DVDs and hard drives, but now have a problem I just can't get my head round. I'd be very grateful for any help any of you can offer.
On my hard drives, some MPG and AVI files simply won't open. I have tried to open these files with VLC Player, the included Windows Player apps, as well as video editing software. Without luck.
In Windows Explorer the files exist with their names but there are no thumbnails. I can right-click on the files and see their properties such as file size etc. I can also copy these files and transfer them but just can't open them!
Outside of Windows Explorer other apps appear not to be able to detect the files. Today I downloaded Wondershare Recoverit. When I clicked on their module to repair damaged video files, I was prompted to choose the files from a pop-up explorer window. But Recoverit couldn't see any files even though the files were in that directory.
I am guessing and hoping that these files are indeed recoverable.
What suggestions do you have? I am afraid of running Windows CheckDisk etc in case it discovers problems which screw up the whole disc.
Thanks in advance for your contributions.
Regards
Steve
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 20 of 20
Steve in Dominican Republic
Try HD Video Converter PRo by WonderFox hopefully it will help. Use the converter option.
open one with a hexeditor and see if there is any data in it.
Thanks to all of you for your suggestions.
I have downloaded and paid for TenorShare4DDiG, and attempted to repair some GoPro files. It's initial attempt at repair failed, so I tried their ADVANCED REPAIR which involves selecting a totally healthy file taken with the same camera, which I did, but that also failed.
I shall now share with the group, specifically with the first person who replied to me (I've forgotten your name, sorry) one of these propblem files in the event that that might help.
Grateful as always
Steve
Steve in Dominican Republic -
Here you go. It's editable, and it's a copy on my Onedrive: https://1drv.ms/v/s!Atb8OWfS8PhckOg56SaE7HqZBFhVFg?e=Kvmfm2
Thanks for your input and suggestions.
MediaInfo on the same MP4 file which I just shared with you, shows the information in the attached BASIC and SHEET views. Basically shows nothing.
What view should I share with you?
Steve
[Attachment 72402 - Click to enlarge]
[Attachment 72403 - Click to enlarge]Steve in Dominican Republic -
Thanks for your suggestion, I opened the same file with a hexeditor, and the file appears to have data, see attached,
[Attachment 72404 - Click to enlarge]Steve in Dominican Republic -
Thanks for your suggestion but that doesn't work either.
I tried converting/importing/editing with Prism, and Video Converter and received similar error messages, see attached.
[Attachment 72405 - Click to enlarge]Steve in Dominican Republic -
Possibly encrypted by ransomeware? Go back to your optical storage, or tape backups and compare.
Scott -
A/V files have identifiable markers at the very start. Those markers are easily seen in a hex editor. For example an mp4 file shows:
[Attachment 72406 - Click to enlarge]
Note the "ftypmp42", "isommp4", etc. Other containers have other markers that make them easily identifiable, even if the extension has been change.
The file you uploaded did not show any of the usual markers. You doubt your going to recover anything from that file. -
the file you posted a screenshot of shows gobbledegook at the beginning. Therefore, you have corruption of the files, for sure. it is either accidental corruption (in which case you should follow best practices for recovery - and that does NOT include using anything by Wondershare!), or it is intentional corruption due to ransomware.
Scott -
Thanks, very grateful. So if it's gobbledygood = corrupt and lost forever?
QUOTE=Cornucopia;2697341] the file you posted a screenshot of shows gobbledegook at the beginning. Therefore, you have corruption of the files, for sure. it is either accidental corruption (in which case you should follow best practices for recovery - and that does NOT include using anything by Wondershare!), or it is intentional corruption due to ransomware.
Scott[/QUOTE]Steve in Dominican Republic -
first thing i'd try is windows disk error checking on the drive. it works well on corrupted files/drives. right click on the drive, properties/tools/error checking. you may have to reboot to get it to run if anything is being used on the drive.
That file I downloaded looked to be encrypted to me. Unlikely a windows file system error or even fixable w/o proper decryption keys. Hopefully you have other backup source? As they say one can never have to many backup copies of important files.
QTGMC won't open a video
By Alwyn in forum Video ConversionReplies: 10Last Post: 20th Sep 2023, 12:38 -
JMkvpropedit 1.5.2 won’t open MKV files in macOS Monterey
By VLConehead in forum MacReplies: 4Last Post: 4th Aug 2022, 12:18 -
Cheap/open-source NLE app to merge audio + video files?
By yetanotherlogin in forum EditingReplies: 5Last Post: 4th Dec 2021, 07:34 -
Tray Won't Open
By Gregavi in forum DVD & Blu-ray PlayersReplies: 1Last Post: 30th Oct 2021, 19:49 -
Is there a video editing software that can actually open video files!?!?!?
By armyofquad in forum EditingReplies: 15Last Post: 4th Oct 2021, 09:42
