Hi, does anyone know of a way of screen recording from streaming sites and get around the black screen?. On my older Toshiba laptop running Windows 8 I was able to screen record using OBS, not sure exactly which browser (think it was with Firefox). I think that was the only screen recorder program that would work besides Bandicam. But now using my new Ideapad with Windows 11 nothing will work. Is this the OS that's doing this or the streaming site?.
Results 1 to 12 of 12
Go into chromes settings and disable the option that says "Use hardware acceleration when available" OBS should then work again and not show a black screen.
[Attachment 72386 - Click to enlarge]I help all that ask. -
Instead of screen recording, would be much easier to directly download. many threads on here to help you & people.
Thanks for that. I think one video I watched mention displaying the options but couldn't quite understand it. When I've used OBS before on my older laptop I found it produced alot of stuttering on playback of the file, more so later in the recording. When I used the trial version of Bandicam there was very little of this even when I used an higher quality and encoding setting.
A lot depends on the sites and their encryption methods. If you are not comfortable with the command line solutions, then GUI softwares might be a lot easier for you to use. They usually offer free trials for example IDM (Internet Download Manager) has 30 days fully functional trial or check the StreamFab products they offer 3 trials on almost all their modules, which is barely enough to see if they are good for any specific site and they are very expensive even when they have a sale.
You can check the list in the forum's software section. -
On this site, only streaming sites that don't need subscription are allowed to be discussed. Therefore there is no reason to be banned.
No worries, but odd why there are threads about coding, you don't need to do that if it's something like youtube, Vimeo etc.
Regarding screencapturing, I don't know why VLC is outputting at an odd framerate (7fps) when I type in 25fps in the "Desired framerate for the capture" box. The outputted video is very stuttery. -
There are so many streaming sites in different countries besides the ones you mentioned. Although they are mostly free but only geoblocked, they use DRM to make it difficult to download.
I don't like to use VLC except for playing videos and certainly not to screen record. IDM is my favorite downloader for non DRM sites. You can DM me if you need help.
Beginners guide to downloading from UK broadcasters streaming sites
By pooksahib in forum Video Streaming DownloadingReplies: 7Last Post: 14th May 2023, 09:10 -
How to download Unprotected Videos from Streaming Sites without IDM ?
By Loryanam2 in forum Video Streaming DownloadingReplies: 6Last Post: 25th Apr 2022, 19:37 -
Recording screen from browser streaming video--questions
By gumbygum in forum Video Streaming DownloadingReplies: 4Last Post: 12th Nov 2020, 14:28 -
Downloading videos from streaming sites (recent change in coding issue)
By Anonymous45 in forum Video Streaming DownloadingReplies: 3Last Post: 5th Aug 2019, 12:29 -
How to download from streaming sites like this?
By jooj in forum Video Streaming DownloadingReplies: 2Last Post: 8th Mar 2019, 04:19
