Hi,
A newbie here. I was trying to download this video clip - https://www.9now.com.au/millionaire-hot-seat/2023/episode-73 and I got an error message that says "this video is DRM protected".
Could you please advise how to download it?
I've tried screen recording as well, but it didn't work.
Thank you.
Results 1 to 17 of 17
I can't access this site because I need to create an account.
Using screen recording is not really the best idea.
Try using TubeDigger it might work -
your using yt-dlp and showing DRM Protected so add --allow-u on cmd
Code:N_m3u8DL-RE -M format=mp4 --key 4241de475062430db605f94fea8eef17:09754af479d7d59dd151dddb084f8234 "https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/4460760524001/ff6609ac-54eb-4a5f-80fd-aa7c74c997a2/2s/manifest.mpd?fastly_token=NjRhZTVmMjJfZGQzOGZlMWFlMzI3ODdhOWE0Yzg4ZDY0M2NlNzY0NjFjMTUwMzk2OTVkYTU1MTAxNTA2YzE1NmRjZjQyM2JiYw%3D%3D" --save-name Millionaire_Hot_Seat_Season_2023
[Attachment 72368 - Click to enlarge]Last edited by iamghost; 11th Jul 2023 at 04:55.
Thank you. I was able to download the file with --allow -u command.
However, I could not play the file afterwards. Will the file still be protected? =S -
h3mlock, now you decrypt the video and audio with the keys iamghost show you in his code (4241de475062430db605f94fea8eef17:09754af479d7d59d d151dddb084f8234)
Use this comment of mine to decrypt https://forum.videohelp.com/threads/410097-Channel-5-download-help#post2694483 -
Hi guys, I tried following this thread, I too am trying to download 9now content, but I can't quiet see what you have done.
I have yt-dlp and ffmpeg installed and have been using them for a few years now, but this is my first time coming up against DRM content with them.
When I run --allow-u on yt-dlp it tells me that its still encrypted and it dumps the video and audio out like normal into my folder, What I don't understand is how you have found the keys/unencrypting the files once I have them locally?
Right now my code looks like this:
Hope you can help me out,Code:yt-dlp --no-part --restrict-filenames -N 4 --ffmpeg-location "C:\Program Files\ffmpeg\bin" -f "bv*+ba/b" --allow-u --user-agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/127.0.0.0 Safari/537.36" --cookies-from-browser chrome --referer "https://www.9now.com.au/" "https://ssaimanifest.prod.boltdns.net/ap-southeast-2/playback/once/v1/dash/live-timeline/bccenc/4460760524001/8d5a1a45-c60e-44a2-a268-949ed95072a1/d0134397-7dc2-42b4-b130-fd20232e5f3d/036919c2-bc67-455d-9ba1-aa1e88379046/content.mpd?bc_token=NjZhOGVmMmRfMzMwNWU5ZTQzN2IyMzFlNjRlYWE1M2E2ODNjNDdmM2U3NDBkNjU5MjIxYWI2MTBkOWQ1ODFjN2FmYzgwNTI1NA%3D%3D&rule=discos-enabled"
I appreciate it
-d -
Well not sure what else you have setup, but what lego pointed to you will be helpful.
You can also useGet the PSSH from the mpd, and use the license url.HTML Code:https://cdrm-project.com/
Paste in, with nothing additinal will give you the key/keys.
Same goes with using ozivine is great -Or I have a basic l3.py script that also works. All give same exact key, so all 3 options work.HTML Code:https://forum.videohelp.com/threads/415165-%5BRelease%5D-Ozivine-Australian-FTA-Downloader
Ozivine is the easiest, fastest. Just relies on python, etc. You can read from that link.
probably the easiest for doing very little but copy/paste and use N_m3u8DL-RE, shaka-packager, mp4decrypt , and ffmpeg in your PATH or in directory where you are running commands from.HTML Code:https://cdrm-project.com/
I picked an Olympic replay for an example just to test.
AUS v CAN | W Pool | Replay
PSSH taken from mpdCode:https://www.9now.com.au/basketball-3x3-olympic-games-paris-2024/season-2024/episode-2
License:Code:AAAAVnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADYIARIQwggPmbavSseT58u3SEJufRoNd2lkZXZpbmVfdGVzdCIIMTIzNDU2NzgyB2RlZmF1bHQ=
Enter them into:Code:https://manifest.prod.boltdns.net/license/v1/cenc/widevine/4460760524001/1ffb3e84-0f58-4070-a90f-2bbf28d5b7d9/c2080f99-b6af-4ac7-93e7-cbb748426e7d?fastly_token=NjZhYTkyYWJfZGE4ZWUyMGMwNTMxY2MzY2EyOWU2YmQ4YWExMzAwMTE1ZDAwMGM3ZTdmOWI4OWE4ZGQ4N2EzMzAxZGFhNDM4OA%3D%3D
[Attachment 81057 - Click to enlarge]
Gives you the key
[Attachment 81058 - Click to enlarge]
User N_m3u8DL-RE key above, and mpd and get the file with the following:Code:--key c2080f99b6af4ac793e7cbb748426e7d:8a5da9f4f774150969c36e56308bc97b
Outputs:Code:N_m3u8DL-RE --key c2080f99b6af4ac793e7cbb748426e7d:8a5da9f4f774150969c36e56308bc97b "https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/4460760524001/1ffb3e84-0f58-4070-a90f-2bbf28d5b7d9/2s/manifest.mpd?fastly_token=NjZhYTkyYWJfMTlmOThjMWNmMTlhZWI1M2MxMDU2YTdjZGZmYzNjZDVmNzI5YTUxMjkyZjMwZTUyYjAxZTA2ZDE3NDc5MDRkNQ%3D%3D" --save-name "AUS v CAN | W Pool | Replay" -M format=mkv
Code:C:\freevine>N_m3u8DL-RE --key c2080f99b6af4ac793e7cbb748426e7d:8a5da9f4f774150969c36e56308bc97b "https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/4460760524001/1ffb3e84-0f58-4070-a90f-2bbf28d5b7d9/2s/manifest.mpd?fastly_token=NjZhYTkyYWJfMTlmOThjMWNmMTlhZWI1M2MxMDU2YTdjZGZmYzNjZDVmNzI5YTUxMjkyZjMwZTUyYjAxZTA2ZDE3NDc5MDRkNQ%3D%3D" --save-name "AUS v CAN | W Pool | Replay" -M format=mkv 15:07:38.884 INFO : N_m3u8DL-RE (Beta version) 20231113 15:07:38.912 INFO : Loading URL: https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/4460760524001/1ffb3e84-0f58-4070-a90f-2bbf28d5b7d9/2s/manifest.mpd?fastly_token=NjZhYTkyYWJfMTlmOThjMWNmMTlhZWI1M2MxMDU2YTdjZGZmYzNjZDVmNzI5YTUxMjkyZjMwZTUyYjAxZTA2ZDE3NDc5MDRkNQ%3D%3D 15:07:40.038 INFO : Content Matched: Dynamic Adaptive Streaming over HTTP 15:07:40.041 INFO : Parsing streams... 15:07:40.200 WARN : Writing meta json 15:07:40.235 INFO : Extracted, there are 9 streams, with 6 basic streams, 3 audio streams, 0 subtitle streams 15:07:40.237 INFO : Vid *CENC 1920x1080 | 4557 Kbps | ff9749a5-4152-4f64-a7cf-6bc2e3eb8809 | 25 | avc1.640028 | 821 Segments | Main | ~27m22s 15:07:40.238 INFO : Vid *CENC 1280x720 | 2402 Kbps | 47cd94eb-eec9-49c9-abb0-5117dc43857b | 25 | avc1.4d001f | 821 Segments | Main | ~27m22s 15:07:40.241 INFO : Vid *CENC 1024x576 | 1645 Kbps | 6b22b970-12ff-44cf-9dde-be5fba241b5d | 25 | avc1.4d001f | 821 Segments | Main | ~27m22s 15:07:40.248 INFO : Vid *CENC 640x360 | 866 Kbps | a98fa33b-ba21-4b15-8801-8c24a1fadc73 | 25 | avc1.4d001e | 821 Segments | Main | ~27m22s 15:07:40.250 INFO : Vid *CENC 384x216 | 456 Kbps | 3a11ec4f-46a4-404c-9b72-dc2b9c3f7d67 | 25 | avc1.42000d | 821 Segments | Main | ~27m22s 15:07:40.252 INFO : Vid *CENC 320x180 | 254 Kbps | 07746371-6dd8-4e3e-9f6a-5984ae761f88 | 25 | avc1.42000c | 821 Segments | Main | ~27m22s 15:07:40.254 INFO : Aud *CENC 36ae27e3-7fcb-4c27-8ee8-4ee126952b7d | 127 Kbps | mp4a.40.2 | en | 828 Segments | Main | ~27m22s 15:07:40.260 INFO : Aud *CENC dc69f6d5-52e0-4d68-9313-ebe604270210 | 96 Kbps | mp4a.40.2 | en | 828 Segments | Main | ~27m22s 15:07:40.263 INFO : Aud *CENC a23a0204-70d1-412f-adfb-1a7d6d72fe27 | 63 Kbps | mp4a.40.2 | en | 828 Segments | Main | ~27m22s 15:25:19.727 INFO : Parsing streams... 15:25:19.734 INFO : Selected streams: 15:25:19.735 INFO : Vid *CENC 1920x1080 | 4557 Kbps | ff9749a5-4152-4f64-a7cf-6bc2e3eb8809 | 25 | avc1.640028 | 821 Segments | Main | ~27m22s 15:25:19.736 INFO : Aud *CENC 36ae27e3-7fcb-4c27-8ee8-4ee126952b7d | 127 Kbps | mp4a.40.2 | en | 828 Segments | Main | ~27m22s 15:25:19.737 WARN : Writing meta json 15:25:19.747 INFO : Save Name: AUS v CAN . W Pool . Replay 15:25:19.748 WARN : MuxAfterDone is detected, binary merging is automatically enabled 15:25:19.750 INFO : Start downloading...Vid 1920x1080 | 4557 Kbps | ff9749a5-4152-4f64-a7cf-6bc2e3eb8809 | 25 | avc1.640028 | Main 15:25:20.870 WARN : Type: cenc 15:25:20.875 WARN : PSSH(WV): CAESEMIID5m2r0rHk+fLt0hCbn0aDXdpZGV2aW5lX3Rlc3QiCDEyMzQ1Njc4MgdkZWZhdWx0 15:25:20.879 WARN : KID: c2080f99b6af4ac793e7cbb748426e7d 15:25:20.883 WARN : Reading media info... 15:25:21.644 INFO : [0x1]: Video, h264 (avc1), 1920x1080 15:27:19.772 INFO : Binary merging... 15:27:20.888 INFO : Decrypting... 15:27:29.852 INFO : Start downloading...Aud 36ae27e3-7fcb-4c27-8ee8-4ee126952b7d | 127 Kbps | mp4a.40.2 | en | Main 15:27:30.138 WARN : Type: cenc 15:27:30.144 WARN : PSSH(WV): CAESEMIID5m2r0rHk+fLt0hCbn0aDXdpZGV2aW5lX3Rlc3QiCDEyMzQ1Njc4MgdkZWZhdWx0 15:27:30.149 WARN : KID: c2080f99b6af4ac793e7cbb748426e7d 15:27:30.154 WARN : Reading media info... 15:27:30.212 INFO : [0x1]: Audio, aac (mp4a), 127 kb/s 15:28:34.011 INFO : Binary merging... 15:28:34.271 INFO : Decrypting... 15:28:34.775 WARN : AUS v CAN . W Pool . Replay.mp4 15:28:34.776 WARN : AUS v CAN . W Pool . Replay.en.m4a 15:28:34.777 WARN : Muxing to AUS v CAN . W Pool . Replay.MUX.mkv 15:28:37.822 WARN : Cleaning files... 15:28:37.965 WARN : Rename to AUS v CAN . W Pool . Replay.mkv 15:28:38.248 INFO : Done
[Attachment 81059 - Click to enlarge]
Long post, just hope it helps clear things up. -
Thank you so much, I think I got it working. Yes I was going to Olympic replays. I have managed to capture the Olympic live streams from 9now with no problem as they haven't encrypted those. Some sports they don't save the streams so you have to capture live, but for the ones that do like the basketball I was hoping I would be able to just grab the replays, and now I can.
Thank you so so much.
You are a legend! -
Please help me with steps to get the highest 4K resolution file for this file, https://olympics.com/en/paris-2024/videos/group-all-around-final-rhythmic-gymnastics-o...mes-paris-2024
I tried Mac Screen Capture on my 6K display, I do not get any audio and i have to leave my monitor on for 2-3 hours.
I am an idiot with Terminal and things of that nature.
Thank you all for you time and instructions.
LostLast edited by chiumeister; 19th Aug 2024 at 17:55.
How do you know that it's 4K? There's only 1080p available.
I found this though, if you really want 4K:
[Attachment 81657 - Click to enlarge]Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2 -
I subscribed to those services, it’s not 4K or 4K HDR. On devices, like Apple TV+ box and others, the source (1080p) is upscaled into 4K. Rec 709 (SDR) into BT.2020 (HDR)
The upscaling sucks. It’s also not AD free. While Youtube premium is AD free, they do not have HDR version. I read Olympics was recorded in native HLG for HDR, but yet to find where it is broadcast or store.
While I enjoy watching my paid services for the upscaled 4K, it’s blotchy, as my internet service isn’t good enough. Hence why i want to download the original source.
Thanks -
I also doubt that they're serving 4k in the browser, so probably only on embedded Android devices, like a FireTV Stick 4K.
The only problem is the a FireTV Stick 4K can't do upscaling, so they can't be lying, and these services must be serving 4K.Bypass HMACs, One-time-tokens and Lic.Wrapping: https://github.com/DevLARLEY/WidevineProxy2
Need help download a DRM protected video
By Frankie21 in forum Video Streaming DownloadingReplies: 5Last Post: 23rd Sep 2022, 13:29 -
Download drm protected video
By me2m8 in forum Video Streaming DownloadingReplies: 3Last Post: 11th Aug 2022, 03:49 -
How can i download mpd video DRM protected ?
By Markoz in forum Video Streaming DownloadingReplies: 10Last Post: 8th Mar 2022, 18:33 -
DrM-protected video download
By WelleTy in forum Video Streaming DownloadingReplies: 5Last Post: 5th Apr 2021, 15:10 -
Download DRM protected video and decrypt it with a drm licence url
By vikral in forum Video Streaming DownloadingReplies: 9Last Post: 9th Feb 2021, 03:14
