Hi,
I recently made a VCd and it played fine on my girlfriend'd Pioneer 515 DVD Player but have just tried a different movie, a SVCD I got from a friend, and it will not read the cd.
The CD-R media can be read by the playe as it is the same makes I used for the VCD (BenQ and Fujifilm) so I do not understand what the problem is.
I also know that the SVCD was burned correctly as it playsback on PC software players.
Does anyone know what the error maybe?
Thanks for any help.! :oops:
you are not alone
http://www.vcdhelp.com/dvdplayers.php?DVDnameid=292&Search=Search&#comments
it works for some but it doesnt for most. -
I just looked that up after posting.
I didn't see it the first time I checked over, thanks for responding.
Antoher question:
If I was to buy a recent dvd player would it likely suppot svcd?
Thanks again Bladrick -
It depends where your player was made. I had a UK spec 515 for nearly three years, but just changed it for a 444. One of the reasons behind my decision was for SVCDs. The 515 just wouldn't recognise the disc. You can burn the file as a VCD, but the playback is messed up.
Basically the only variation on VCD that it would accept for some reason, was 48khz audio of any bitrate.
Hope this helps
Nick
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 07:25 -
Pioneer dv-400v XVID playback problems
By ironzenmountain in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Sep 2008, 00:22 -
Pioneer DVR 630 HS - Recording will not playback
By ktmsprocket in forum DVD & Blu-ray RecordersReplies: 3Last Post: 14th May 2008, 13:06 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
SVCD: Picture is not completely displayed during playback
By czerro in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2007, 14:53
