Hi
I have a Panasonic DMR-EX87 which has stopped working. When I power it on it says U81. The content on the recorder is very important so Im contemplating just fixing the recorder depending on the the cost. Im concerned the repair cost may be close to the price of buying a newer model as the EX87 is 10 yrs old.
- Does anyone know if I can just remove the HDD and install it in a newer model Panasonic?
- If not is it possible to copy the HDD to a computer then for me to copy videos to a new Panasonic recorder?
Anthony
I can only help you with the copying of the HDD content. If you get to that stage and you have the HDD in your hand (I am guessing it is a SATA HDD 2.5"), then you just buy a HDD to USB adapter like this one without enclosure or one with enclosure, respectively.
https://www.amazon.com/gp/product/B07452Z3KH/ref=ox_sc_saved_image_7?smid=A2XZ7JICGUQ1CX&psc=1
https://www.amazon.com/UGREEN-External-Enclosure-Adapter-Housing/dp/B06XWRRMYX?ref_=as..._dp&th=1&psc=1
Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
By Brad in forum Capturing and VCRReplies: 466Last Post: 22nd Aug 2025, 08:30 -
Panasonic dmr eh50.
By AMYFAITH in forum Newbie / General discussionsReplies: 30Last Post: 21st Apr 2024, 22:55 -
Panasonic DMR-BCT74ENK - cannot copy XP recorded footage to external HDD
By guy24s in forum DVD & Blu-ray RecordersReplies: 14Last Post: 15th Jan 2024, 01:20 -
Panasonic DMR and Macrovision
By SmurfRecorder in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th May 2021, 12:29 -
Panasonic DMR HDD to SSD change
By gargap in forum DVD & Blu-ray RecordersReplies: 4Last Post: 18th May 2020, 01:02
