    Aug 2018
    Wrocław
    This:
    for %%a in ("*.mp4") do ffmpeg -i "%%a" -vf "vidstabdetect=shakiness=10:accuracy=15:result='%%~na.trf':show=1" dummy.avi -y
    But this:
    for %%a in ("*.mp4") do ffmpeg -i "%%a" -vf "scale=in_range=full:out_range=full,curves=master='0.0625/0 1/1',vidstabdetect=shakiness=10:accuracy=15:result='%%~na.trf':show=1" dummy.avi -y
    results with this with every frame.
    [vidstabdetect @ 00000097695fedb8] too low contrast. (no translations are detected in frame 34)
    Why this doesn't work?
    There seems to be a problem with "curves=master='0.0625/0 1/1'" -- it works fine without it.
  2. Originally Posted by rgr View Post
    The message says "too low contrast"
    Try lowering the mincontrast
    https://ffmpeg.org/ffmpeg-filters.html#vidstabdetect-1
    mincontrast
    Set minimum contrast. Below this value a local measurement field is discarded. Must be a floating point value in the range 0-1. Default value is 0.3.
    Aug 2018
    Wrocław
    Not working.
    After
    vidstabdetect=shakiness=10:mincontrast=0:accuracy=15:result='%%~na.trf':show=1
    still every frame has "too low contrast".
  4. Do the 1st pass analysis on the "normal" video, write the .trf
    Do the 2nd pass (assuming you want to stabilize it) with your scale/curves filter and vidstabtransform
    Aug 2018
    Wrocław
    Pass 1 and pass 2 only work if "curves=" is removed. If I leave "curves=" on the second pass, ffmpeg aborts and I get a file of length 0.
    It seems that the curves output is incompatible with vidstab.
    But it works when I put "curves=" at the end (after vidstabtransform). However, I would prefer to put before.
