    May 2023
    Can anyone help extracting these .wvm files? I can't find any info on them.
    Link to my archive (Note: The other one on my page doesn't work.): https://archive.org/details/scc-sd
    Mar 2008
    Did you try ffmpeg? Something like:
    ffmpeg.exe -fflags +genpts -r 29.97  -i "C:\Users\davex\Downloads\FE_Bob_the_Builder_-_Scoop_the_Artist_10.19.wvm" -c copy outfile.mkv
    May 2005
    PAL User
    No go here, it stops at 10sec. Handbrake, VDub do the same.
    Mar 2008
    Yes I noticed that, but that particular source does that when you play it in mpc-hc.
    Problem in source?
    May 2005
    PAL User
    The DRM, methinks. It gives you a little taste then slams the door shut. I was looking forward to a dose of Feathersword!
