I have captured a number of DV tapes using my Macbook Air via the firewire interface and I am wanting to convert/compress them into mp4 files to share online. I have copied the files to my Windows PC and have tried using Hybrid with default settings to convert them but I am getting an issue with the audio.
The audio seems to be stretching out to double the length of the original clip. If I do the conversion without audio the video file is the correct length but if I add audio, the file runs for twice the length but the video is running at normal speed but stops halfway through and the audio is running half speed.
Is there some settings I can change to fix this?
TIA
Here are the file details from MediaInfo:
General
Complete name : C:\Users\xxxxxx\Documents\1999-03-29 19_59_40-1.mov
Format : MPEG-4
Commercial name : DVCAM
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 1.31 GiB
Duration : 6 min 4 s
Overall bit rate : 30.9 Mb/s
Frame rate : 25.000 FPS
Recorded date : 1999-03-29 19:59:40.000
Encoded date : 2023-05-21 10:39:33 UTC
Tagged date : 2023-05-21 10:45:38 UTC
Writing library : Apple QuickTime
com.apple.quicktime.make : Apple
com.apple.quicktime.model : MacBookAir6,1
com.apple.quicktime.software : macOS 11.7.7 (20G1345)
com.apple.quicktime.creationdate : 2023-05-21T11:32:40+0100
Video
Format : DV
Codec ID : dvcp
Source duration : 6 min 4 s
Bit rate mode : Constant
Bit rate : 24.4 Mb/s
Width : 720 pixels
Clean aperture width : 703 pixels
Height : 576 pixels
Clean aperture height : 576 pixels
Display aspect ratio : 4:3
Original display aspect ratio : 4:3
Clean aperture display aspect ratio : 4:3
Frame rate mode : Constant
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Interleaved fields
Scan order : Bottom Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 2.357
Time code of first frame : 00:00:00:07
Time code source : Subcode time code
Stream size : 1.22 GiB (93%)
Source stream size : 1.22 GiB (93%)
Title : Core Media Video
Color primaries : BT.601 PAL
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio #1
Format : PCM
Format settings : Little / Signed
Codec ID : lpcm
Bit rate : 2 048 kb/s
Channel(s) : 4 channels
Channel layout : L R L R
Sampling rate : 32.0 kHz
Bit depth : 16 bits
Stream size : 89.1 MiB (7%)
Source stream size : 89.0 MiB (7%)
Title : Core Media Audio
Audio #2
Format : PCM
Format settings : Big / Signed
Muxing mode : DV
Muxing mode, more info : Muxed in Video #1
Bit rate : 768 kb/s
Channel(s) : 2 channels
Bit depth : 12 bits
Stream size : 33.4 MiB (2%)
Audio #3
Format : PCM
Muxing mode : DV
Bit rate : 768 kb/s
Bit depth : 12 bits
Other
Type : Time code
Format : QuickTime TC
Time code of last frame : 00:06:00:07
Time code, stripped : No
Title : Core Media Time Code
Default : No
Results 1 to 9 of 9
Yes the videos play fine on the PC. I’ll have a look at HD Video Converter but as I’ve got hours of video to convert I was wanting something free.
You should have captured your DVCAM tapes into DV-AVI not .mov, Not a lot of software can work with that weird format especially when the audio is 32Khz/12bit. If you can re-transfer your tapes you can avoid few lossy conversions.
Except, capturing via a Mac, the container will almost ALWAYS be mov (or its cousin mp4), because that is the native format of the OS.
( Certain pro proprietary systems can cap to DV in mxf, and systems based on ffmpeg could conceivably use other formats).
Scott -
Yes, that's why Mac is not recommended for this kind of tasks, It's a closed ecosystem, It requires everyone on the planet to have a Mac to be issue free.
That's not necessary. All they want to do is convert DV to MP4. I'll bet there's dozens of converter programs that will do it. And they're not doing "few lossy conversions".Originally Posted by Dellsham
I gave up on Hybrid. The interface is complex and there was always something in a nook and cranny somewhere that tripped up what I was trying to do. In the right hands it's probably good but it is not user-friendly.
Strange issue DeInterlacing DV capture - QTGMC-Bob (Hybrid Vapoursynth)
By SupermanTV in forum Capturing and VCRReplies: 23Last Post: 17th Sep 2023, 18:00 -
VHS Audio capture issues
By ChrisStout in forum Capturing and VCRReplies: 6Last Post: 20th Aug 2023, 04:36 -
RealCUGAN in hybrid vs Waifu 2x Extension Gui (slow in hybrid)
By Platos in forum Newbie / General discussionsReplies: 1Last Post: 28th Apr 2023, 06:43 -
VHS-C unidentifyed tape and issues.
By harrypm in forum MediaReplies: 3Last Post: 3rd Oct 2022, 23:27 -
VCT tape video capture: Tape shows annoying VCR Speed and Tracking bar...
By MoonView in forum Capturing and VCRReplies: 7Last Post: 5th Apr 2021, 22:52
