I've been doing a lot of VHS conversions lately that have been going well, but one thing I noticed was that when capturing to AVI via RCA cables, it is showing as a progressive scan file. I did not think that they made any VHS players that output in progressive scan. Do any of you know? I was wondering if this was a software capture error or if in fact it is a progressive scan file.
The player that i'm using is a Sony SLV-D370P, and while it has a progressive scan DVD player built in, it says nothing about the VHS player.
Results 1 to 15 of 15
Just because mediainfo says it's progressive, doesn't meanit actually is. Open in in Virtualdub, find a place with some steady movement and
look at it one frame at a time. Or post a sample here to the forum direct from the capture -
Opened in virtualdub, and going frame by frame during motion, each frame is a completely different standalone image. See attached 5 frames.
VHS is interlaced only. But the content can be progressive. It can be 30 fps or 24 fps or whatever else cadence that can be. If the content is 30 fps, and your container does not correctly report the stream type, you can have the stream reported as progressive while having actual progressive content. Yay, the stars have aligned.
I see many 1990s music videos recorded as 30p (30 PsF if you will). I wonder have they been shot on film at 30 fps, or videotaped normally, then deinterlaced into 30p for film-like motion. -
What digitiser and capture program are you using?
Re "RCA cables", do you mean the yellow, Composite video sockets? It's best to use an S-Video cable for video. -
I'm using Avermedia DVD EZmaker7 with Power Director 14 to capture to a 640x480 @29.97fps avi. The connection I have is the composite video (single yellow plug for video, and red and white for audio channels). I dont have access to any VHS players with S-video output. Interestingly, this sony player I have outputs S-video, but only for the DVD side.
I wonder if the digitizer is deinterlacing? -
I suggest capturing something that is supposed to have live look, like home video, news or sports. Although you never know... I see sports at 30p now on TV.
Don't use the software that comes with the capture device, It usually have options for changing resolution and de-interlacing. Use vdub or AmarecTV, your captures should come out lossless AVI 720x480 @ 59.94 fps (fields per second), You can then use another program to de-interlace, set the aspect ratio flag and encode to a more manageable format such as h.264.
Interesting, when using vdub, it comes in at 29.97
Video:
Frame size, fps (µs per frame): 720x480, 29.970 fps (33367 µs)
Length: 4450 frames (2:28.48)
Decompressor: Internal DIB decoder (YUY2)
Number of key frames: 0
Min/avg/max/total key frame size: (no key frames)
Min/avg/max/total delta size: 0/690578/691200 (3001050K)
Data rate: 165573 kbps (0.00% overhead)
Audio:
Sampling rate: 48000Hz
Channels: 2 (Stereo)
Sample precision: 16-bit
Compression: PCM (Uncompressed)
Layout: 109 chunks (1.37s preload)
Length: 7119030 samples (2:28.31)
Min/avg/max/total frame size: 164568/261248/262144 (27809K)
Data rate: 1536 kbps (0.01% overhead) -
I will say that I have tinkered with vdub and handbrake and never got the videos to look anywhere near as good as the ones I get from using powerdirector, encoded to mpeg-2.
In the sample you provided, the 2 fields are from the same moment in time, so the souce is not a "real" interlaced video. You can process it as if was progressive.it is showing as a progressive scan file
Captured VHS tv recording looks progressive (but should be interlaced)
By dave_van_damme in forum Video ConversionReplies: 50Last Post: 3rd Mar 2024, 18:11 -
[Problem] Quality VHS to Firewire scan via Camcorder
By pablitooo66 in forum Capturing and VCRReplies: 25Last Post: 7th Jan 2023, 16:46 -
newbie wants to scan his vhs tapes
By jmonty55 in forum Newbie / General discussionsReplies: 6Last Post: 25th Dec 2021, 20:15 -
Forced scan type to "Progressive" after VirtualDub encoding
By GD314 in forum Video ConversionReplies: 5Last Post: 13th Mar 2020, 12:06 -
Panasonic dmr-es10 progressive scan vhs
By tuberlildk in forum Capturing and VCRReplies: 3Last Post: 10th Sep 2019, 08:45
