    Apr 2002
    Ireland
    Does anyone know how to play incomplete divx files downloaded with grokster?
    When i try grokster's own player it says "player error".
    I want to see what i'm getting before i download the whole file!
  2. yea grab DivFix
    I use it to figure out if I want to finish downloading a DivX
    it will re-index the file so you can watch it -- you can download it from the tools section here I think
    your pal,
    Stinky
  3. Member spidey's Avatar
    Apr 2001
    U.S.A.
    You can use the DivFix,
    OR
    Just rename the file extension to .avi and open the file in VIrtualDub.ebuild the index for you so you can preview it all
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  4. Spidey you are right - but if you want to look quickly through a movie to see if the quality is good enough to keep downloading then DivFix is the way to go --- the VirtualDub way does not allow you too 'drag' and 'seek' very easily, unless you 'direct stream copy' save the file first.
    But both ways work... so it depends on what your used to doing.
    your pal,
    Stinky
