When relative path is added in "Custom Subtitle Storage Locations"
[Attachment 72237 - Click to enlarge]
The player totally ignores "Load any subs in folder if none matches" setting and load EVERY subtitle from that folder.
I've contacted the support and they've replied with:
And indeed, if set to full path, it works properly - no subtitles are loaded if non matched filename.Relative paths have been modified to load all subtitles, which is intended.
In other words, the previous version has a bug, and the current one is working properly.
My question to you guys is, in what circumstance this could possibly be a desired behavior??? (I'm referring to relative paths would produce different result then full paths), would you consider this as a feature or a bug?
And just in case, this was "fixed" in v220831, so the last working version is v220706
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Potplayer - Subtitles in single line instead of two
By ihuman in forum Software PlayingReplies: 8Last Post: 7th Sep 2022, 11:58 -
PotPlayer not finding all available subtitles using OpenSubtitles
By bloodhand in forum Software PlayingReplies: 1Last Post: 27th Oct 2021, 19:29 -
Moving subtitles in potplayer
By Valerio in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2020, 21:26 -
Potplayer subtitles Not showing question
By Budman1 in forum SubtitleReplies: 0Last Post: 28th Mar 2020, 01:27 -
Potplayer - Disable Subtitles?
By vanbrocklin in forum Software PlayingReplies: 2Last Post: 28th Dec 2019, 21:34
