Hi there
I have some VCDs that were saved on an HDD many years ago in BIN & CUE files, and I wish to be able to find a way to extract these files the easy way. I have downloaded PowerISO, which I used many decades ago, but I cannot find any easy way of using it, other than creating virtual drives, which are not suitable for my needs?
And before anyone mentions ISOBuster, I had the paid version many decades ago as well, but forget my registration details, and don't actually see the need to pay for it again as I can use Hybrid to extract the actual DAT files into a decent format.
Really, what I am after, is some unzip type of program that will recognize the files and extract them back to how they would look as if I had just created a folder of the original discs and dragged and dropped all of its contents into it
Try
https://www.videohelp.com/software/vcdgear
VCDGear is a program designed to allow a user to extract MPEG streams from CD images, convert VCD files to MPEG, correct MPEG errors, and more -- all in a single step. Initially developed back in late 1997, the program has grown to do various extractions, conversions, and corrections on the fly. Cross-platform support will allow different machines to process and generate output that is compatible between one another.Last edited by ProWo; 4th Jul 2023 at 09:00. Reason: changed url to intern software section
How to decrypt YouTube Movies & TV files
By user10thousand in forum Video Streaming DownloadingReplies: 84Last Post: 3rd Sep 2024, 19:42 -
Extracting AAC LC & shortening silences from MPEG-4?
By DynVec in forum AudioReplies: 4Last Post: 21st Jun 2023, 04:58 -
Need help!! Extracting Audio from video files.
By Salarian in forum AudioReplies: 2Last Post: 12th Nov 2021, 04:00 -
Are timecode files needed when extracting audio to use in a different video
By beany in forum Newbie / General discussionsReplies: 8Last Post: 8th Dec 2019, 13:04 -
Extracting FPS from multiple files
By [ss]vegeta in forum Newbie / General discussionsReplies: 2Last Post: 14th Feb 2019, 03:31
