Results 1 to 1 of 1
    Jun 2023
    Beach Lake PA
    Chroma key aka green screen is something I've used in many contexts, but today I'm getting weird effects with the Panasonic MX70 mixer. This mixer has 3 chroma key settings and one can set the color to be keyed by activating a cursor which acts as a color picker and pressing enter when cursor is over the desired color. This seems to work, with different RGB numerical values entering the screens for key 1 2 and 3, and staying in memory.
    Key controls include setting K level or specificity of range of the key color, and slice and slope controls to fine tune edges. These seem to work roughly as expected.
    However, the 3 key settings seem to all do exactly or almost exactly the same thing. I created an image with RGB areas to color pick which set different apparently correct RGB values for the 3 keys. Key 1 seems to work correctly [Green] But when I switch from Key 1 to Key 2 or 3 [red, blue], I see zero difference in what is keyed out. What might I be doing wrong? I referred to the manual and some online videos without being helped.
    Update 7/19 With more experimentation, I found the answer in my wrong assumptions. All 3 keys are always simultaneously active whenever Chroma is on, which is why nothing changes when switching from key 1 to 2 or 3; all that does is allow tweaking of the settings for that key.
