I want to encode my mpeg-1 films to divx format.I make ripping file.dat from cd with vcdgear.Then I try to encode virtualdub and flaskmpeg,It be sometimes ,don't be sometimes.Mpeg-1 to divx conversion have very problems.
Once I have tried to encode with Tmpeg.It was do but not sound.
Please,May you suggest mpeg(dat) to divx ways and quides me.?
Thanx,Can...![]()
Mpeg is divx. Divx is the codec (COmpression/DEComprssion) used to compress the video in the decoding process and decompressthe video so that you can watch them on your computer. If you want to convert mpeg 1 to avi you can use faskmpeg you can get that @ http://www.flaskmpeg.net/
I went to look for myself, if I get back before I return, Keep me here. -
VirtualDub would work well for this. Get the lastest version of Virtualdub, get the Nimo Codec Pack (from the Tools section), open the MPEG file in ViertualDub, choose one of the DIVX codecs for compression and output the video to DIVX. I have done that many times to add subtitles to movies I have gotten in MPEG format.
Cheers
Arnaud
Divx multipass encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2009, 12:31 -
Divx Author 1.5 Re-encoding standard divX files
By ejai in forum Authoring (DVD)Replies: 2Last Post: 9th Jul 2008, 19:28 -
DivX Encoding Problems
By ftshark in forum DVD RippingReplies: 3Last Post: 7th Mar 2008, 11:30 -
DVD to DivX encoding?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 12:33 -
Cut Divx without Re-encoding
By kman22 in forum EditingReplies: 8Last Post: 26th Nov 2007, 18:39
