Hello Everyone,
I have this error on ripbot264 after importing an avs script:
DePanEstimate: Can not load fftw3.dll or libfftw3f-3.dll !
(C:\Program Files (x86)\AviSynth+\plugins64\Stab.avsi, line 15)
(C:\Users\David GC\Desktop\Saint Seiya ANIME script\Saint Seiya 1080p.avs, line 16)
(E:\Temp\RipBot264temp\job2\getinfo.avs, line 2)
The avs script is attached.
What i am doing wrong ?
Results 1 to 15 of 15
Did you put fftw3.dll in the windows system folder?
https://forum.videohelp.com/threads/409769-FFTW-Library-AVISynth-Info-Tool-Error-Message -
for the 32 and 64 bit versions, extract the contents and rename "libfftw3f-3.dll" to "FFTW3.dll.
Move the 32 bit version to \windows\syswow64 and the 64 bit version to \windows\system32
Once that is done you can troubleshoot your script further as necessary -
What original fftw3.dll ??
The archive fftw-3.3.5-dll??.zip does not contain that file -
You're wright, i was confused by another version downloaded on internet.
I have done what you said but still the same error loading the script.
(E:\Temp\RipBot264temp\job2\getinfo.avs, line 2) -
He must mean old versions or either fftw3.dll or libfftw3f-3.dll in either c:\windows,
c:\windows\system32 or c:\windows\sysWow64.
If you find something delete them and put the new 64bit version of fftw3.dll in system32 and the
32 bit version of fftw3.dll in sysWOW64 -
HCenc Help creating AVS script. newbie!
By Rom7x in forum Authoring (DVD)Replies: 2Last Post: 11th Feb 2022, 03:54 -
Selur Hybrid: how to export profile and/or AVS script
By Darryl In Canada in forum RestorationReplies: 1Last Post: 7th Feb 2022, 11:11 -
Colour of video changes when using FFMPEG with AVS Script
By bradwiggo in forum Video ConversionReplies: 5Last Post: 3rd Jul 2021, 05:51 -
Merging of multiple sources in AVS script
By KenshinX in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2020, 16:01 -
multiavchd error [AVS] Cannot detect script properties!
By digicube in forum Authoring (Blu-ray)Replies: 0Last Post: 8th Mar 2020, 14:49
