Hi
I would like to find a DVD menu creation software where you can create your own DVD menu, and you can use your own images as background, not just the template ones. Also, it needs to be free, and without a watermark. Can someone please help me?
Results 1 to 10 of 10
avs2dvd, havent used it in ages but it does what you want, if you have already compliant dvd video/audio files it will do everything from creating menu, dvd structure, burning dvd etc, dvdstyler is also a good choice.
if you want something more powerfull and have the time to learn it you can use dvd lab pro, it has a 1 month fully functional trial.I love it when a plan comes together! -
AVStoDVD is easy to use and can create menuless DVDs and DVDs with basic DVD menus. AVStoDVD can re-encode video and audio to fit on a single layer DVD or dual layer DVD.
There is another free option for DVD authoring, DVDStyler, that also allows creating more complex menus, although using it requires more knowledge.Last edited by usually_quiet; 2nd Jul 2023 at 15:50.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
DVDstyler is free, as is AVStoDVD
I use AVStoDVD and have been for a good few years, the menu system can be a bit fussy sometimes but virtually everything is editable from the background to the fonts, spacing, thumbnails, backgrounds, buttons, almost all via the menu system without any editing of awkward options and you can see exactly what the menu would look like on DVD
Neither have been updated for a couple of years, BUT they still work. I'm using Windows 11 and it still works fine from Windows XP to Windows 11
I've also use AviSynth+ latest releases, plus I use the latest version of MKVToolnix and latest 32-bit compiles of FFMPEG (64 bit FFMPEG WILL NOT WORK). to keep things updated
If you just want a menu editor, try DVDStyler first
AVStoDVD is a good bit of software and pretty much point and click conversion and DVD creation, but uses AviSynth to encode. If want very powerful (and a bit complex) restoration encoding software, That's another huge forum on its own but can achieve very good results
https://codecpack.co/download/AVStoDVD.html -
In Windows there's avs2dvd, dvdstyler, and gui for DVD author. I've used all 3 and each have their strengths. In Linux dvdstyler is all I use as the other 2 don't work even with wine. All 3 will make a DVD menu for free. If your doing non standard stuff like 480x480, 528x480 kdvd(kvcd) resolution etc on DVD then avs2dvd wont work as it's good about forcing compliant DVD parameters. This is good for most people and cases but not if your intentionally trying to author non-standard stuff as I do lol.
if all else fails read the manual -
Click Dvd Menu, Menu Editor. Bottom left under "mode" click edit.
Software DVD menu creation
By Donnje in forum Authoring (DVD)Replies: 5Last Post: 10th Dec 2022, 02:23 -
is there software that only changes the background color of a dvd menu?
By lorenzo111 in forum Authoring (DVD)Replies: 7Last Post: 7th Dec 2021, 10:53 -
Menu creation advice needed, possibly with DVD-Styler
By Reddwarf4ever in forum Authoring (Blu-ray)Replies: 15Last Post: 8th Sep 2020, 03:46 -
Inconsistent MDS file creation with ISO creation in ImgBurn
By Seeker47 in forum DVD RippingReplies: 3Last Post: 22nd Jun 2020, 04:47 -
Software for Dazzle Digital Video Creator 150 & DVD Creation Station 200?
By vintagecap in forum Capturing and VCRReplies: 2Last Post: 19th Mar 2020, 20:12
