  1. I want to rip seasons 2-4 of VIP off of CTV. I have been doing with on TUBI using command prompt programs. Is there something out there to do the same thing for CTV?
    Mar 2021
    Israel
    It is geoblocked.
    Try TubeDigger it might help. It usually works in rec mode for this kind of sites.
  3. Wouldn't that give me a really crappy copy of the show? I want to be able to rip a quality version of the show.
    Mar 2021
    Israel
    No. You will get the best quality. Check the FAQ
    https://www.tubedigger.com/faq.html
    Is 'Rec Mode' like screen capturing?
    'Rec Mode' is NOT screen capturing. In 'Rec Mode' TubeDigger records media packets that come through network card and recorded file has quality as in 'D-L Mode'.
  5. The last time I ripped something from CTV, the content was encrypted with widevine.
    Mar 2021
    Israel
    TD can download it without any problems. The best part is that it skips the ads. See this sample image.
Name:	CTV Sample 1C.jpg
