which one is the best dvd burner(cheap and good quality), and what kinds of media this supports?
hi all
i m back
which one media is more compatible with stand alone players?
and what burners to use in it? -
I would suggest either a DVD-R capable drive like the Pioneer A04 or a DVD+R capable drive like the HP 200i.
DVD-R is more established and the media and drives are more available and are cheaper, but DVD+R seems to work well also, and the burning speeds are slightly faster, especially for DVD+RW over DVD-RW media.
It also depends on what drives/players you'll be using the discs with. If just a few it might pay to see what is compatible with them. If with both DVD+R and DVD-R then you can choose. If with one or the other, then your decision is already made for you.
Check my sig for more info. -
thanks for help...
ill have 4 months to decide.
here in Brazil the dvd-writers r very expensive yet(arround 800 bucks).
ill go to Vegas in September and ill buy it.
Really thanks..
Best DVD BURNER?
By nj473 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Mar 2010, 19:40 -
New DVD Burner
By pepegot1 in forum DVD & Blu-ray WritersReplies: 11Last Post: 23rd Feb 2010, 00:57 -
DVD Burner
By jason in forum Newbie / General discussionsReplies: 8Last Post: 15th Feb 2008, 16:02 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
burner not seeing dvd
By SiberSan in forum ComputerReplies: 1Last Post: 1st Oct 2007, 13:46
