Hello, I wonder how I can increase Video Decode to speed up encoding?
I use QSVEnc for encode, which can reach 200fps with that setting. (--avhw --cqp 19:20:22 --profile high --level 5.2 --output-thread 1)
Anyone can help me? Thanks for your reply
[Attachment 72174 - Click to enlarge]
I see you are using the Intel HD Graphics 530
Perhaps using a GPU with more VRAM can help. -
other setting anything without buying new VGA? lol
I can't set more vram because I set max of this. -
You don't have to buy a GPU to test.
Use Google Colab resources
https://www.tutorialspoint.com/google_colab/google_colab_using_free_gpu.htm
I haven't been able to try Colab because my Google Drive got corrupted.
Let me know if this helps. -
Try a counter-intuitive thing - switch to sw-decoder instead of hw-assisted one.
The overhead of sending data between GPU and CPU often too big and turns supposed speed advantage into a disadvantage. -
Follow transcode guidelines https://trac.ffmpeg.org/wiki/Hardware/QuickSync if you not using any filter requiring CPU then this is fastest path.
Best way to not need 4k proxy files? Faster CPU, faster GPU, or more RAM?
By GoodEnough in forum Newbie / General discussionsReplies: 7Last Post: 6th Feb 2023, 23:34 -
make VDub2 faster?
By taigi in forum RestorationReplies: 3Last Post: 7th Jun 2021, 11:44 -
Any Faster Way for De-interlacing Using QTGMC?
By dellsam34 in forum Video ConversionReplies: 93Last Post: 23rd Dec 2020, 20:05 -
Does encoding in Handbrake without Audio make the encode faster?
By focuspuller in forum Video ConversionReplies: 10Last Post: 11th Jan 2019, 05:18 -
subtitle getting slower or faster than video
By amink69 in forum SubtitleReplies: 0Last Post: 3rd Oct 2018, 04:43
