I recall back in the good old days, we have madVR to upscale videos. What's the modern day equivalent, and is there anything else I can send to my GPU to maximize its use?
Thanks!
Results 1 to 9 of 9
To maximize your RTX 3060 Ti's use:
Enable hardware acceleration in applications that support it.
Leverage GPU compute for tasks like machine learning or simulations.
Optimize game settings for a balance between visuals and performance.
Keep GPU drivers up to date. -
Sounds like someone asked ChatGPT.
The modern day equivalent is to use AI upscaling, but with a 3060 you're not going to get close to realtime. Check out Topaz or ESRGAN and you'll find your GPU totally maxed. -
I have suspected that Dorothy's posts were not written by a human from the start. It's good to know that I am not alone in my suspicion.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Hi! Do you also use Lightroom? I've used both Lightroom & Topaz sometime back, but feel that Topaz doesn't really edge out Lightroom and I still have to export them to a separate app for processing.
ESRGAN looks cool though - is there a frontend GUI for it so beginners can use it? 😅
look forward to other useful applications that can maximize my GPU! -
Even well-regarded free software doesn't always get frequent updates.
I don't currently use either madVR or RTX Super Video Resolution. I tried madVR recently but not for upscaling and don't have an NVIDIA GPU. I did read that RTX Super Video Resolution was good for upscaling video.
(I tried madVR and then MPC Video Renderer with MPC-BE for HDR-10 pass-through to my new 4K TV but neither worked for some reason. I decided that if I had to rely on tone mapping, I preferred MPC Video Renderer for that.)
[Edit]Here is a link to the VLC fork with support for RTX Video Super Resolution: https://downloads.videolan.org/testing/vlc-rtx-upscaler/Last edited by usually_quiet; 30th Jun 2023 at 22:37.
Bug: Potplayer "maximize" click turns to full screen and hides taskbar
By mayheamk in forum Software PlayingReplies: 3Last Post: 28th May 2025, 02:26
