Greetings ,
Windows 11 , smplayer Version: 22.7.0 (revision 10091) (64-bit)
I have a playlist of audio files containing 103 spearate files .
But the speaker talks too fast for my tastes .
How can I set the speed , globally for this playlist ?
Thanks for your Help...
Greetings ,
I found an answer here :
https://www.portablefreeware.com/forums/viewtopic.php?p=105060#p105060
I generally listen to Librivox recordings using smplayer :
https://www.portablefreeware.com/index.php?id=1358
and sometimes I want to slow down the recording .
Here is a tip how to do that :
One option is to mess with the global speed setting. Open Options -> Preferences -> Advanced -> MPlayer/mpv, and add --speed=0.9 (or any speed you like) to the Options field. You can them remove it once you've listened through the whole playlist .
htm...
Global TV Video Download
By takistexas in forum Video Streaming DownloadingReplies: 9Last Post: 18th Oct 2024, 03:29 -
By takistexas in forum Video Streaming DownloadingReplies: 2Last Post: 17th Feb 2023, 09:59 -
How do I prevent MKVToolNix from creating global tags?
By fltk10 in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2021, 10:00 -
Make playlist play in browser's native player
By DWIChannel in forum Newbie / General discussionsReplies: 73Last Post: 19th Sep 2020, 10:58 -
Smplayer - where is the bookmarks folder kept ?
By Atotaloss in forum Newbie / General discussionsReplies: 0Last Post: 30th Nov 2018, 05:31
