What I want to do is:
I want to make 3D blu-ray video side by side without going through ripping on a pc in a small work room, and do local streaming to a pc with vr equipment in a large play room.
Due to the specifications and layout, it is difficult to replace the PC and extend the cable, so is there any way to meet the above conditions?
As far as I checked, it seems that mpc + madVR can be used for side by side only, and vlc can be used for local streaming output only, but I could not find a way to achieve both.
Worst case, I feel like I can capture the screen of mpc and stream it locally with obs etc., but it doesn't feel very smart.
Isn't it possible with ffmpeg or something?
Also, both PCs are windows.
Results 1 to 1 of 1
HD video capturing devices and their audio limitations
By carlmart in forum Capturing and VCRReplies: 35Last Post: 11th Nov 2021, 05:58 -
FFMPEG Save video from rtsp stream to hls stream
By Wisperrio in forum Video Streaming DownloadingReplies: 2Last Post: 26th Aug 2021, 22:38 -
Why does muxing a video stream into a MKV file change that stream?
By 4L7zHhiyQO3Thui6 in forum Video ConversionReplies: 14Last Post: 11th Mar 2021, 03:45 -
Choppy video playback on multiple devices
By birdus in forum Software PlayingReplies: 4Last Post: 9th Jul 2020, 14:05 -
Exact same GPU model plays 2160p video smoothly on only one of two devices.
By LG7 in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2020, 10:53
