TLDR:
I sucessfully got an output video with correct audio and burned-in subtitle.
BUT the video length is now 1194:39::27. I also cannot use VLC's video seek slider.
The source video is only around 1:36:52.
ffprobe results on my source.mt2s file
This is the command that I used:Code:Program 1 Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p(tv, bt709, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn Stream #0:1[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:2[0x1101]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s Stream #0:3[0x1200]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090) Stream #0:4[0x1201]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
If I used this command, it gives me correct video length and seeking in not a problem except I don't have burned-in subtitle.Code:ffmpeg.exe -i "source.m2ts" -filter_complex "[0:v][0:s:1]overlay[v]" -c:v hevc_amf -quality 0 -rc 0 -qp_p 25 -qp_i 25 -c:a libfdk_aac -b:a 320k -map "[v]" -map 0:a:1 "output.mkv"
Code:ffmpeg.exe -i "source.m2ts" -c:v hevc_amf -quality 0 -rc 0 -qp_p 25 -qp_i 25 -c:a libfdk_aac -b:a 320k -map 0:v -map 0:a:1 "output.mkv"
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
ffmpeg - muxing with a subtitle
By donelle82 in forum SubtitleReplies: 0Last Post: 15th Oct 2022, 08:19 -
ffmpeg mkv dts to mkv pcm24 bit
By insurancepi in forum Newbie / General discussionsReplies: 13Last Post: 15th Mar 2022, 13:02 -
Ripping DVD to MKV- one disk is not working correctly
By JDMils in forum DVD RippingReplies: 4Last Post: 14th Jun 2021, 09:16 -
ffmpeg Burn ASS Subtitle Batch Script
By Daringbaaz in forum Newbie / General discussionsReplies: 3Last Post: 12th Jun 2021, 01:45 -
MkvMerge - Copy all subtitle tracks and chapter info from one MKV to MKV
By Vitality in forum Newbie / General discussionsReplies: 1Last Post: 9th Mar 2019, 15:34
