  1. Hi,
    trying to dl (preferring realtime playing) an MSS Smooth manifest.
    Here's that I've just tried.
    N_m3u8DL-RE --save-name TEST ".isml/Manifest" --key kid:key --live-real-time-merge --tmp-dir TMP --live-pipe-mux --auto-select
    It'll generate a new TEST.und.ts but it is Zero byte and cannot reproducible. Also m4s generated in m4s-video folder are not playing but they've got a dimension.
    Are there any possibilities to playing a mux in real time generated by N_m3u8?
  2. Did you figure this out?
  3. No, but also with Win version of N_m3u8 same error. Cannot reproduce mux pipe file generated.
  4. i think you have downloaded without key ... so N_m3u8DL-RE can't merge your final file. key needed
  5. No man I've insert kid and key. Can you see here?
    Manifest und with zero kbps also if I stop.
  6. wrong key
    your key 939 ... is for sport/24
    try your mpd (right) with this key:
    b9fd6af212944c879239bcec7e17238c:c8d9ed7de4c662b5740cb78b3674a621
  7. Yes excuse me but in my haste I copied the key wrong, but at the same time I have the same error. The mux pipe does not play.
    Not mpd is and MSS
    N_m3u8DL-RE http://url/Manifest --mp4-real-time-decryption --live-real-time-merge --live-pipe-mux --key b9fd6af212944c879239bcec7e17238c:c8d9ed7de4c662b57 40cb78b3674a621
  8. yes, i know
    i can run some test and me too have the same issue ... something is wrong
    also i've another mpd for sport/24 with another key and here i have this error:
    ERROR: One or more errors occurred. (The SSL connection could not be established, see inner exception)
    i think this streaming service have been change some stuff, after leaked data .... end of games ...
