Hey,
Is there a way to add shadows to PGS subtitles? I know it would be simpler to just use OCR to convert them to SRT and then configure settings accordingly, but OCR introduces so many errors that it would be unfeasible for me to manually correct them all.
The problem is that one of my closest friends has vision problems that make it difficult for him to see PGS subtitles because they're just white text and that's it — he's used to white text on a translucent black background, y'know? — and I figure that it since it's easy to add a translucent black background to normal PNG/JPG/HEIC/TIFF images, it should be possible to do the same to pictographic subtitles such as PGS (and VOBSUB). But I'm not sure how to edit them like pictures, let alone how to do so in bulk.
My primary computer is a Mac, but I do have access to a PC that I can use if necessary.
Have you tried converting PGS subtitles to srt?
You can use SubtitleEdit for PC but perhaps there is an Apple App for Mac.
Changing Color of PGS Subtitles
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 8th Nov 2022, 01:41 -
Subtitles S_HDMV/PGS
By sutor2008 in forum SubtitleReplies: 6Last Post: 17th Oct 2022, 12:02 -
WD TV Gen 1.PGS Subtitles Gibberish
By sambat in forum SubtitleReplies: 4Last Post: 15th Jul 2021, 19:02 -
Converting 2D PGS subtitles to 3D HalfSBS PGS subtitles
By RajaSteve in forum SubtitleReplies: 66Last Post: 15th Nov 2019, 08:13 -
Aspect ratio of pgs subtitles
By alexwk in forum SubtitleReplies: 1Last Post: 4th Sep 2018, 22:37
