Results 1 to 25 of 25
  1. Banned
    Apr 2022
    Hong Kong
    --key a8ebb6e7a21febf3ee49af72fdd613cc:6b7a356b69b5b4943e68681aa7b6d891
    P.S. The x-custom-data expires fast, so you have to be quick or it may expire.
    Nov 2014
    Germany
    Thank you for the answer!
    Any command and which tool I must using for download?
    Greetings!
  3. Banned
    Apr 2022
    Hong Kong
    As for N_m3u8DL-RE, use the command below:
    N_m3u8DL-RE.exe "https://npo-nl-ams-p29-am5.cdn.streamgate.nl/eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJleHAiOjE2ODczNjg3ODIsInVyaSI6Ilwvdm9kXC9ucG9cL3VzcFwvVEVTVFwvbnBvXC9kYXNoX2NlbmNcL1dPX1ZQUk9fMjAwNjY3NTdcL1dPX1ZQUk9fMjAwNjY3NTdfdjE2ODcwODk0NTMuaXNtIiwiY2xpZW50X2lwIjoiOTEuNjYuMjQ0LjU3Iiwidmlld2VyIjoiNmZkZjY3MjIyMDE5NWJkMGNmNjIyNzRjYjU4MjAyZTllMzFiMjhkNSIsInJpZCI6IjVhYjg5ODgifQ.EuJyQisJ5drqq8TCfwY4hvNTPugY4MvAEsvYHL5lQSI/vod/npo/usp/TEST/npo/dash_cenc/WO_VPRO_20066757/WO_VPRO_20066757_v1687089453.ism/stream.mpd" --key a8ebb6e7a21febf3ee49af72fdd613cc:6b7a356b69b5b4943e68681aa7b6d891
    Remember to refresh the page and get a new mpd link if the mpd files on this website will expire.
  4. Hi, thanks for your help. Would you mind explaining how you retrieved the license for this concert / site? I've been trying to locate the license file, but I don't manage to understand where it could be found.
    Thanks in advance!
  5. how you retrieved the license for this concert / site
    load page (https://3voor12.vpro.nl/speel~WO_VPRO_20066757~queens-of-the-stone-age-live-at-pinkpop-2023~.html)
    open dev tools
    refresh page
    run video
    filter at Network for authentication
    https://npo-drm-gateway.samgcloud.nepworldwide.nl/authentication
    get curl of the call
  6. Thanks a lot, you made my day!
  7. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Originally Posted by ghostrewel View Post
    Hi folks!
    I want to download following video:
    Found following link:
    https://npo-nl-ams-p29-am5.cdn.streamgate.nl/......
    How can I grab thse?
    Any help was great!
    Greetings,
    ghostrewel
    You should really remove that MPD link, as it contains your IP. Just saying
  8. You should really remove that ....
    I think that it may be a tad difficult now that you have quoted it.
    Only a suggestion, perhaps, you may consider removing it also.
  9. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    Good call!
    Sorry, it's late and I should really go to bed.
  10. I'm trying to download the exact same video, that's how I stumbled on this page. Please excuse my question, it's my first time doing this.
    I've got a folder with N_m3u8DL-RE.exe, ffmpg.exe, and mp4decrypt.exe in it.
    I opened up Edge DevTools, went to Network and searched for mpd so I've got the stream.mpd
    How do I find what goes in --key ?
    If I leave that part out and run N_m3u8DL-RE.exe it shows me that KID: a8ebb6e7a21febf3ee49af72fdd613cc , so that's the same.
    But I know I need the key in order for what I download to be playable.
    Thanks for the help.
  11. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    --key a8ebb6e7a21febf3ee49af72fdd613cc:6b7a356b69b5b4943 e68681aa7b6d891
  12. Oh so the whole thing stays the same. OK. Thanks. I thought it would change when the mpd address changed.
    So how would I find that 6b7... on my own?
    I was trying to follow this thread, so in DevTools I went to Network and filtered on Authentication but I don't see that in there.
  13. Search, Learn, Download! Karoolus's Avatar
    Oct 2022
    Belgium
    You would need a CDM and then a script that will allow you to request the decryption key from the license server.
    If this doesn't make sense to you, I'd suggest reading up on this forum, as a lot of it is explained here in several threads. It's quite a lot of information to just dump here
  14. OK, will do. Thanks for your help on this one and I'll do some more reading.
  15. Could someone help me out with the keys for this one?
    https://www.2doc.nl/documentaires/2024/01/bassie-en-adriaan-een-schat-aan-herinneringen.html
    I can't manage to get it and have tried in several different ways.
    (unfortunately not with local CDM as I do not really know how that works).
    But I just need the decryption keys so that i can download it via N_m3u8DL-RE.
    Thanks in advance?
  16. Member aqzs's Avatar
    Mar 2024
    Paris
    Originally Posted by shadyjam View Post
    Key :
    dde060f32e03870388d9b840630fd504:7e13b313b0c981e9fc91e2b40f7b2e77
    Command :
    N_m3u8DL-RE --key dde060f32e03870388d9b840630fd504:7e13b313b0c981e9fc91e2b40f7b2e77 "https://npo-nl-ams-p16-am3.cdn.streamgate.nl/TRUCADED/vod/npo/usp/TEST/npo/dash_cenc/AT_300015432/AT_300015432_v1705145312.ism/stream.mpd" -M mkv --save-name "Bassie en Adriaan - Een schat aan herinneringen"
    https://www.swisstransfer.com/d/ddc8bf58-751c-424b-80c8-ef4f44afce4b
    added subtitles : https://www.swisstransfer.com/d/d7183f28-f52a-4c34-960b-0e07cf5b2a20
  17. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
  18. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Thanks a lot!
    Works perfectly fine.
    How did you manage to do it?
    I received 401 authorization blah blah error everytime.
    You don't have to explain if it's complicated but I really appreciate it!
  19. Member aqzs's Avatar
    Mar 2024
    Paris
    The license token expire really fast just make sure to grab a fresh one.
  20. Originally Posted by aqzs View Post
    Aaah, I read something about that above, so tried my best but didn't manage to do it.
    So thanks a lot for the help, really appreciated!
  21. Feels Good Man 2nHxWW6GkN1l916N3ayz8HQoi's Avatar
    Jan 2024
    Pepe Island
    I just used a local cdm. I usually just copy paste the license call and use curl converter.
  22. Originally Posted by 2nHxWW6GkN1l916N3ayz8HQoi View Post
    Is it easy to get a local CDM?
    I have read some about it, but not sure if it's needed to be taken from an Android device?
    Also read something that it's possible to make one via android studio so looking into that.
  23. Originally Posted by shadyjam View Post
    from real android device
    https://github.com/hyugogirubato/KeyDive
    or
    https://github.com/FoxRefire/wvg/wiki/How-to-dump-CDM-key-pair-from-physical-device
    from virtual android
    https://github.com/FoxRefire/wvg/wiki/How-to-dump-CDM-key-pair-from-AVD
  24. Originally Posted by Silv3r View Post
    ifrom real android device
    or
    Thanks again!
    May have to get an Android device, will look into it!
