The Hitachi-LG GP96Y is a Android DVD Player that is giving five chances to select a region, I am after a solution & some advice.
1. After a comprhensive search have not found a DVD Region hack, and without a remote or anywhere to input details not sure there is a way, but if anyone knows then would be appreciated
2. If above fails, when I am about to play a DVD I have recorded as 0 Region, what of the 5 options should I use in the Regions, so I can continue to play my 0 region DVD's to the Android in the future if no Region Hack is available & I use up my 5 chances.?
Thanking all in anticipation
Thank you for the reply
I guess when it all boils down if there is no region hack, then my question is if I select region 1 will I still be able to play my region 0 DVDs on my Android player ? If that is the case I would be happy with that, if anyone is able to confirm -
I think this should answer your question
https://en.wikipedia.org/wiki/DVD_region_code -
Thankyou my good man, answers my question.
I have DVD Decrypter on my Computer (still), and just checked a disc I did, & it is Region 1-8, so that won't be a problem going forward.
pioneer DV-3052V region free: SKIPPING, 'out of region' error
By Favorite in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Oct 2022, 14:19 -
Region free
By animalia in forum DVD & Blu-ray PlayersReplies: 10Last Post: 9th Sep 2022, 12:59 -
Region Free
By ricketts in forum DVD & Blu-ray PlayersReplies: 7Last Post: 14th Sep 2020, 15:39 -
Region free dvd player
By thyer2a@bigpond.com in forum Newbie / General discussionsReplies: 1Last Post: 30th Dec 2019, 04:24 -
Region free Philips HTB3280G
By Marissa in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Nov 2019, 12:42
