Can anyone explain why ffmpeg/ffprobe can not load this manifest url:
https://q-hss-skylive-degn.akamaized.net/244431/stream.isml/Manifest?quality=hss5_dd
ffprobe returns:
Code:ffprobe https://q-hss-skylive-degn.akamaized.net/244431/stream.isml/Manifest?quality=hss5_dd ffprobe version 4.2.7-0ubuntu0.1 Copyright (c) 2007-2022 the FFmpeg developers built with gcc 9 (Ubuntu 9.4.0-1ubuntu1~20.04.1) configuration: --prefix=/usr --extra-version=0ubuntu0.1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-avresample --disable-filter=resample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librsvg --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-nvenc --enable-chromaprint --enable-frei0r --enable-libx264 --enable-shared libavutil 56. 31.100 / 56. 31.100 libavcodec 58. 54.100 / 58. 54.100 libavformat 58. 29.100 / 58. 29.100 libavdevice 58. 8.100 / 58. 8.100 libavfilter 7. 57.100 / 7. 57.100 libavresample 4. 0. 0 / 4. 0. 0 libswscale 5. 5.100 / 5. 5.100 libswresample 3. 5.100 / 3. 5.100 libpostproc 55. 5.100 / 55. 5.100 https://q-hss-skylive-degn.akamaized.net/244431/stream.isml/Manifest?quality=hss5_dd: Invalid data found when processing input
Yes I have been playing but not sure why its not piping anything.
The streams are live video which I pipe and stream over http using python and flask. I don't want to save to file.Code:N_m3u8DL-RE <URL> --key <KEY> --decryption-binary-path C:\Bento4\bin\mp4decrypt.exe -sv best -sa all -ss all --live-pipe-mux True
How to detect empty subtitles with ffprobe/ffmpeg?
By jack616 in forum SubtitleReplies: 1Last Post: 19th Mar 2023, 00:32 -
Let me know the exact syntax of either ffprobe or ffmpeg to know if all the
By jraju in forum Newbie / General discussionsReplies: 32Last Post: 20th Mar 2021, 21:45 -
How do I pass values from FFProbe to FFmpeg?
By Bassquake in forum ProgrammingReplies: 12Last Post: 10th Feb 2021, 09:39 -
ffmpeg hls_key dont load the .ts
By vl4d in forum Video ConversionReplies: 0Last Post: 29th Jan 2021, 16:05 -
ffmpeg vs ffprobe frame count speed
By Anime4000 in forum Newbie / General discussionsReplies: 6Last Post: 12th May 2019, 05:05
