Good morning everyone,
Hope someone could help me ^^
With tsMuxeR 2.6.12 I replaced one audio track and one subtitle track
Then I simply changed the m2ts file into my blu-ray and tried it
The audio keeps the same trackid and play fine, the subtitle do not
So I tried with the latest version of tsMuxeR from github
The audio and the subs keeps the correct ID, so when I change them into the menu they are selected, but for unknown reason (to me) when I press play the video is totally off for about 1 hour, then playing fine
I tried with BDEdit v0.56 looking inside it into the PLAYLIST and CLIPINF sections, but I can't find a way to change the trackID for the subtitles
Can you help me?
Thanks a lot ^^
After a lot of tests I found out how to solve my issue!
If anyone need it, I used tsMuxeR 2.6.12
When I got the new tracks IDs I opened the BDMV folder with BDEDIT, found out the streaming with all the tracks (audio and subs) and replaced the code with the new track ids
Eventually you need a mini guide, let me know so I will provide you ^^ -
Hello again everyone!
Still me, still having issues
I tried to do the same thing on another UHD BD, but using tsMuxeR 2.6.12 I got error "Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name:"
I can manage it with the last version of tsMuxeR, but as the other one when I play it it stays black screen for about 1h and then start
I tried to edit the start point from bdedit setting to 0:0:0, the movie play fine but the start point is always at about 1h
Any help please? ^^
Back Up UHD
By Captainfearless in forum Authoring (Blu-ray)Replies: 2Last Post: 25th May 2023, 21:10 -
HD to UHD HDR10?
By meimeiriver in forum Newbie / General discussionsReplies: 6Last Post: 5th Feb 2022, 07:21 -
Why is the JAWS 4K UHD streaming quality, better than my JAWS 4K UHD disc?
By ZackyDog in forum Video Streaming DownloadingReplies: 25Last Post: 28th Oct 2021, 04:23 -
UHD mkv to BD-R DL50GB - tool to shrink >50K UHD MKV to BD compliant BDMV?
By njweb in forum Blu-ray RippingReplies: 6Last Post: 5th Mar 2021, 03:07 -
Can i mux or remux 4K UHD ?
By ningnong132 in forum Authoring (Blu-ray)Replies: 7Last Post: 5th Dec 2018, 17:40
