    Jan 2023
    Portugal
    Im using this script to get an ts file with live stream:
    N_m3u8DL-RE.exe --save-name test "https://host&start=LIVE&end=END" --live-real-time-merge --live-pipe-mux --auto-select --live-wait-time 5 --key 000000:000000
    In this way the video/audio is downloaded to .ts and then transmitted.
    It is possible to make this .ts just transmit directly.
    By the way, does anyone know what the command is for
    --live-pipe-mux
  2. Banned
    Apr 2022
    Hong Kong
    I would prefer this command below:
    N_m3u8DL-RE.exe --live-real-time-merge --live-pipe-mux --live-record-limit 02:00:00
    To be frank, the instruction is very clear on their GitHub page, so you could look for some details there.
    P.S. As for encrypted HLS streams like HBO Go live channel, you do not need to input the key, in that it will automatically detect the keys in the manifest.
    The command "--live-pipe-mux" means that a pipe will be created and the program will mux all the streams includin' the video stream, and audio stream(s).
    Jan 2023
    Portugal
    @CrymanChen thanks mate
