Page 2 of 2
FirstFirst 1 2
Results 31 to 41 of 41
  1. 403 Forbidden
    your IP isn't France IP. or maybe wrong IP for your site ... use some VPN (with express can work fine)
    edit: oh yes, as sk8ordi3 says, wrong double quote!
  2. Image
    [Attachment 71953 - Click to enlarge]
    I just changed them and here is what I have
  3. And why not without quote in url like I did ?
  4. Image
    [Attachment 71959 - Click to enlarge]
    And There you go ...
    It does the same
  5. Be careful you have spaces in yours keys.
  6. try this only
    m3u8 "https://mpd_link"
    for this test forget all keys. you need to see all res available. if you can see this, add all keys (without space)
    @nic030
    a long mpd link without " " does not work fine in N_m3u8DL-RE
  7. SO :
    1 - Thanks for the quotes and the spaces, it unlocked
    2 - Regarding the 403 error, I am in France with a French IP but to be sure, I tried with a vpn in Paris and it is still a 403 error?
    Here is my code:
    m3u8.exe -M format=mp4 --key d235461f2ab05c039f1eeb4fe9627472:0aae478fcfcd723fa7d6aa2cf00c623e --key d7d34c382b605e0db7527f7722385c44:1f6ffda83c95da677feface3802b71f8 --key b7b8eac9bf00516fbfe3838fb500136b:7be5a5be3d55229ce5e2a05b2c17922c https://vod-das.cdn-0.diff.tf1.fr/eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjaXAiOiI5Mi4xODQuOTguNTQiLCJjbWNkIjoiIiwiZXhwIjoxNjg3NjA3MjQxLCJnaWQiOiJlZjE5NDU3Yy02N2ZiLTQ2ZWUtYmIzMS1jZmU0N2VlMDZhZjYiLCJpYXQiOjE2ODc1OTI4NDEsImlzcyI6ImRlbGl2ZXJ5IiwibWF4YiI6MjgwMDAwMCwic3RlbSI6Ii8yL1VTUC0weDAvNTcvNTUvMTM5OTU3NTUvc3NtLzlhMWI3YmU1ODE5NjNmODAwYTI3N2U3ZGFjNWMxY2MzMDVjMWQ3MGIwMTY2MmVjNmQwOWU4MGU2ODA2ZDkyMTguaXNtLzEzOTk1NzU1Lm1wZCIsInN1YiI6ImVmMTk0NTdjLTY3ZmItNDZlZS1iYjMxLWNmZTQ3ZWUwNmFmNiJ9.WMWoDpGCYHUTnDVmk_VRZnRaVN68SlyNHQL2DwujjZ0/2/USP-0x0/57/55/13995755/ssm/9a1b7be581963f800a277e7dac5c1cc305c1d70b01662ec6d09e80e6806d9218.ism/13995755.mpd
    The first test on the image is with a VPN in Paris and the second with my French IP
    [Attachment 71983 - Click to enlarge]
  8. @alexandre91
    the token in the mpd link is constantly changing
    i.e. it expires, but I see you are still using the same mpd link after several hours
  9. Oh ok thank you @sk8ordi3
    I'll try again and let you know
  10. yes, use fresh mpd
    and again, put mpd into double quote
    [Attachment 71985 - Click to enlarge]
  11. Hi to all!
    I have a problem with a TF1 video program.
    I noted his drm with the Stream Detector https://vod-das.cdn-0.diff.tf1.fr/eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJjaXAiOiI5Mi4...m/13997611.mpd
    i know too his licence URL https://widevine-proxy-m.prod.p.tf1.fr/proxy?id=13997611&rn=1&ssc=acd8fb1b-0cae-42d6-b...3&e=1687897580
    i don't know how to determinate the famous PSSH and keys.
    I already tried these 3 url websites to find them (https://cdrm-project.com/ + https://tools.axinom.com/decoders/PsshBox + https://base64.guru/converter/decode) but i didn't find them for a week with this thread.
    Thanks a lot to try to help me.
