  1. I got an .ass, which I converted to ttxt.
    Since using:
    -add "G:\Output\test_0.ttxt":name="TEST_TITLE":lang="aa"
    with MP4Box works, I think the .ttxt file is fine.
    Problem is when I call ffmpeg with:
    ffmpeg -y  -r 25/1 -i "J:\tmp\2023-06-18@07_43_36_4710__04.mkv" -i "G:\Output\test_0.ttxt" -vcodec copy -scodec copy -metadata:s:s:1 handler="TEST_TITLE" -metadata:s:s:1 language="aar" -metadata encoding_tool="Hybrid 2023.06.17.1" -map 0:0 -map 1:0  -aspect 640:352 -r 25/1 "G:\Output\test.mp4"
    I get:
    Input #0, matroska,webm, from 'J:\tmp\2023-06-18@07_43_36_4710__04.mkv':
      Metadata:
        encoder         : libebml v1.4.4 + libmatroska v1.7.1
        creation_time   : 2023-06-18T05:43:46.000000Z
      Duration: 00:00:17.16, start: 0.000000, bitrate: 427 kb/s
      Stream #0:0: Video: h264 (High), yuv420p(tv, bt470bg/unknown/unknown, progressive), 640x352 [SAR 1:1 DAR 20:11], 25 fps, 25 tbr, 1k tbn (default) (forced)
        Metadata:
          BPS             : 423490
          DURATION        : 00:00:17.160000000
          NUMBER_OF_FRAMES: 429
          NUMBER_OF_BYTES : 908387
          _STATISTICS_WRITING_APP: mkvmerge v76.0 ('Celebration') 64-bit
          _STATISTICS_WRITING_DATE_UTC: 2023-06-18 05:43:46
          _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    [in#1 @ 0000023364906bc0] Error opening input: Invalid data found when processing input
    From the looks of it ffmpeg has a problem with the input file.
    => Does anyone know how to use FFmpeg to mux .ttxt subtitles?
    Cu Selur
    Apr 2018
    Croatia
    XML based subtitles decoding/demuxing is not implemented
  3. argh,.. so I would have to convert them to srt first.
    Thanks for the info.
