I have a MiniDV tape ripped to avi (NTSC!):
Code:Video ID : 0 Format : DV Codec ID : dvsd Codec ID/Hint : Sony Duration : 1 h 33 min Bit rate mode : Constant Bit rate : 24.4 Mb/s Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Original frame rate : 29.970 (29970/1000) FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:1:1 Bit depth : 8 bits Scan type : Interlaced Scan order : Bottom Field First Compression mode : Lossy Bits/(Pixel*Frame) : 2.357
When I try to open this file via Avisynth:
I get this error:Code:ffms2("2.avi",atrack=-1) QTGMC(preset="slow")
[avisynth @ 000001d4f581e340] MDegrain1 : no valid OVERSCHROMA function for 16x16, bitsperpixel=8, lsb_flag=0, level=1
(C:/Program Files (x86)/AviSynth+/plugins64+/QTGMC.avsi, line 879)
(2.avi.avs, line 2)
(@ preset ="slower")
Avisynth open failure: MVTools: no BLITCHROMA function for block size 4x16 (C:/Program Files (x86)/AviSynth+/plugins64+/QTGMC.aysi, line 642)
Why?
Might be mvtools2 not supporting 4:1:1, it' s not listed
https://github.com/pinterf/mvtools
Supporting YUY2, 4:2:0, 4:2:2, 4:4:4 at native 8, 10, 12, 14 and 16 bit depths, 32bit float in selected filters. -
Did you mean this parameter ?
http://avisynth.nl/index.php/Convert#Chroma_resample
It's the algorithm used to resample the chroma
It probably won't be that significant for a NTSC DV source , but it depends on what you are doing exactly
There are times when you might want "blocky" chroma, and use "nearest neighbor" to up and downsample . For general use the bicubic is probably a good choice. For sharper chroma, you might want lanczos, but it predisposes to chroma ringing artifacts because it's sharper
MiniDV—> h265 + QTGMC +mp3192 with hybrid don’t play audio
By Trevi1 in forum Video ConversionReplies: 2Last Post: 14th Dec 2022, 08:16 -
Joint MiniDV file + create chapters + QTGMC + H265
By Trevi1 in forum EditingReplies: 3Last Post: 8th Dec 2022, 12:28 -
Chroma Trails from analog NTSC video
By cjdavis83 in forum Video ConversionReplies: 9Last Post: 30th Dec 2021, 08:06 -
Question about NTSC chroma subcarrier
By Videogamer555 in forum DVB / IPTVReplies: 1Last Post: 15th Feb 2021, 08:54 -
Deinterlacing Problem - QTGMC & NTSC Footage
By hickeyguy in forum Newbie / General discussionsReplies: 50Last Post: 8th Mar 2019, 11:41
