Results 1 to 25 of 25
    Nov 2022
    Brazil
    Hello
    I managed to find the PSSH and the license link, but when generating the key it is returning an error (Code 500).
    Can you generate a key and decrypt normally for this link?
    https://v.youku.tv/v_show/id_XNTk1MzE2MzA1Ng==.html?s=afab1c1855394aa2988a&spm=a2hje.1...k1MzE2MzA1Ng==
    PSSH: AAAASnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAACoSENdyuh oYZA3pvW1zPiLDwCUSENdyuhoYZA3pvW1zPiLDwCVI88aJmwY=
    License sever: https://drm-license.youku.tv/ups/drm.json
    m3u8: https://pl-ali.youku.tv/playlist/m3u8?vid=XNTk1MzE2MzA1Ng%3D%3D&type=cmfv4hd2&ups_clie...p_key=34300712
    Obs: The first few minutes of the video is not encrypted.
    Who can help me thank you.
    Nov 2022
    Brazil
    Were you able to decrypt with the information they passed you?
  3. What tools are you using? Youku requires custom script and will not work with sites likes cdrm-project or getwvkeys.
    --key d772ba1a18640de9bd6d733e22c3c025:0f0a8ddc6082e473bd35b011fa1203f9
  4. nxhda
    Sep 2022
    I don't know how to write a script, can you guide me
    Nov 2022
    Brazil
    I'm using the EME script to get PSSH and firefox to find that license link I put in the above post.
    To generate the key I use a cdm with the WKS-KEYS tool.
    I don't know if the PSSH and License Link are right or wrong.
    If you can help me I would be grateful
  6. Originally Posted by andertjf View Post
    To generate the key I use a cdm.
    maybe you didn't understand the words of stabbedbybrick: the question isn't right pssh or lic url, but need custom script to get your key ...
    Nov 2022
    Brazil
    Thanks.
    In this case I am using the WKS-KEYS tool
  8. ... and for WKS-KEYS tool need custom script
    does not work with l3.py
    Nov 2022
    Brazil
    Can you help me how can I create it or where can I learn about it?
  10. audio
    ffmpeg -user_agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36" -referer "https://v.youku.tv/" -i "https://valipl.cp31.ott.cibntv.net/6974CED0F7F3F71BB544D6390/07000000006455E13914C7D03743AAA06FEDE2-87CC-451A-95E2-E65C567EF7CA.m3u8?ccode=0597&duration=2595&expire= 18000&psid=4b0b8e2b82b214eaf925375557b86f6741346&u ps_client_netip=43471613&ups_ts=1687008151&ups_use rid=&apscid=&mnid=&rid=20000000F880FA96ABE788DB339 B010D8E911DD602000000&operate_type=1&umt=1&type=cm fv4hd2&utid=BKEUHTei4GUCAUNHFhPZ2HgH&vid=XNTk1MzE2 MzA1Ng%3D%3D&s=afab1c1855394aa2988a&t=f942294dfadd 6b&cug=2&bc=2&si=5&eo=1&ckt=5&m_onoff=0&vkey=Bd7ec 852c2bc985c26b68aa5384c0a22b&fms=66242518a17b753c& tr=2595&le=5fa82a8a9e9b465633a03bce6c7c3dc3&app_ke y=34300712&app_ver=9.3.14" -c copy "audio.ts"
    video
    ffmpeg -user_agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36" -referer "https://v.youku.tv/" -i "https://valipl.cp31.ott.cibntv.net/67747DE483A4B7211228D2CE8/0500CC00006455E1D22F2D3F8B69BBECB4DFE6-4A41-4659-BBAE-3AD7FB1E35D6.m3u8?ccode=0597&duration=2595&expire= 18000&psid=4b0b8e2b82b214eaf925375557b86f6741346&u ps_client_netip=43471613&ups_ts=1687008151&ups_use rid=&apscid=&mnid=&rid=20000000F50C7BC41E02E0D1D17 2E767B5A44C6E02000000&operate_type=1&umt=1&type=cm fv4hd2&utid=BKEUHTei4GUCAUNHFhPZ2HgH&vid=XNTk1MzE2 MzA1Ng%3D%3D&s=afab1c1855394aa2988a&t=f942294dfadd 6b&cug=2&bc=2&si=5&eo=1&ckt=5&m_onoff=0&vkey=B0bc2 5003a3d622af4164b17379521622&fms=ffe63516c2ef831f& tr=2595&le=f9ef85e9267cec00c2159d40fb7705b0&app_ke y=34300712&app_ver=9.3.14" -c copy "video.ts"
    Kindly download and mux.
    Nov 2022
    Brazil
    Originally Posted by jack_666 View Post
    audio
    video
    Thanks Jack, I already have the files but my question is about decryption.
  12. use stabbedbybrick key with mp4decrypt
    video
    mp4decrypt --key d772ba1a18640de9bd6d733e22c3c025:0f0a8ddc6082e473bd35b011fa1203f9 video.mp4 video_dec.mp4
    audio
    mp4decrypt --key d772ba1a18640de9bd6d733e22c3c025:0f0a8ddc6082e473bd35b011fa1203f9 audio.mp4a audio_dec.mp4a
    join with ffmpeg
    ffmpeg.exe -i video_dec.mp4 -i audio_dec.mp4a -c copy final_video.mp4
    Nov 2022
    Brazil
    video
    audio
    join with ffmpeg
    I would like to learn about the script, I don't want to depend on others to generate the keys.
    I have other videos to decrypt, this was just an example I gave to learn about.
    If you can direct me where I might be learning about it I would be very grateful.
  14. Originally Posted by NBA456017
    In order to write a functioning script, you'd need to learn Python. At least if you're using Pywidevine. And that is completely up to you. I can, however, give you some pointers.
    Youku, and many other services, send and request information as JSON objects. If you look at the sticky post by A_n_g_e_l_a where she writes about this very thing, you'll see examples of what that might look like if you want to use WKS. You parse the data, generate your challenge, b64encode it, and insert it at the proper place. In many cases, the data is already in JSON, but in youku's case it comes as a series of key:value pairs. So you need to first parse it into JSON, and then insert your challenge at the proper dictionary key, which in this case is fittingly named ["licenseRequest"]. And then you send the request to the license server.
    And then you have to do the same thing for the response. It's generally a good idea to print out the steps along the way to see what's happening.
    And yes, your PSSH and license url are both correct.
    Nov 2022
    Brazil
    Thank you so much stabbedbybrick, I will try to understand better. Thanks again for the valuable tips.
  16. Banned
    Apr 2022
    Hong Kong
    I agree with @stabbedbybrick, in fact he has explained much of it.
    You need some python knowledge to create a customized script for Youku.
    [Attachment 71834 - Click to enlarge]
    and your key is
    However, I would like to say something that y'all didn't mention.
    You could use N_m3u8DL-RE to download and then decrypt the video stream and audio streams by using the command:
    N_m3u8DL-RE.exe "https://pl-ali.youku.tv/playlist/m3u8?...&cmfvFileId=0500CC00006455E058A93C6BFA90C70D4A2E57-D07C-4D4E-B00B-E218A212DED5&cmfaFileId=07000000006455E00CB521711381F91C1A6C2A-800A-4E91-A651-AB86E9C9439C&..." --key d772ba1a18640de9bd6d733e22c3c025:0f0a8ddc6082e473bd35b011fa1203f9
    Last edited by CrymanChen; 19th Jun 2023 at 14:56. Reason: Added how to download & decrypt altogether.
  17. Originally Posted by CrymanChen View Post
    and your key is
    i used your method to download files from youkutv. but it seem like key doesn't work anymore and video still encrypted
    any help please
  18. Banned
    Apr 2022
    Hong Kong
    Then send the URL of the video you want to download, only in this way can we help you get the keys.
    Otherwise are you waiting for me to sort everything done for you?
  19. Originally Posted by CrymanChen View Post
    i have to download videos for everyday . it would be great if you could sort everything for me.
    i will buy u a coffee ^_^. because i really need to know how to download from youku.
    i can use custom script . but to create the custom script i have zero knowledge of python.
    https://v.youku.tv/v_show/id_XNTk3NjE3MjE1Ng==.html?s=fddae7e0941b4d1283fb&spm=a2hje.1...k3NjE3MjE1Ng==
    Dec 2021
    england
    @lukhitt1992
    its only V.I.P member to view 1080p
    free 720p
    50a842ea1654d8ec4008adf003535beb:6e1ea3691714f6a0bb7d2b691be78d92
  21. Originally Posted by iamghost View Post
    its only V.I.P member to view it
    https://v.youku.tv/v_show/id_XNTk3NTM3NTU4OA==.html?s=fddae7e0941b4d1283fb&spm=a2hje.1...k3NTM3NTU4OA==
    this one is free.
  22. Originally Posted by iamghost View Post
    @lukhitt1992
    free 720p
    video is still encrypted after using your key.
    N_m3u8DL-RE (Beta version) 20230618
    21:10:31.086 INFO : Loading URL: http://valipl10.cp31.ott.cibntv.net/697543F046C4471DF477E24D2/0500CC000064954EC1607873...&app_ver=9.4.0
    21:10:31.755 INFO : Content Matched: HTTP Live Streaming
    21:10:31.756 INFO : Parsing streams...
    21:10:31.757 ERROR: Failed to get KEY, ignore.: One or more errors occurred. (The 'skd' scheme is not supported.)
    21:10:31.760 WARN : Writing meta json
    21:10:31.762 INFO : Extracted, there are 1 streams, with 1 basic streams, 0 audio streams, 0 subtitle streams
    21:10:31.763 INFO : Vid *UNKNOWN Kbps | 217 Segments | ~45m20s
    21:10:31.763 WARN : An unrecognized encryption method is detected, binary merging is automatically enabled
    21:10:31.763 INFO : Selected streams:
    21:10:31.763 WARN : Writing meta json
    21:10:31.765 INFO : Save Name: 0500CC000064954EC1607873AF7E2B1A03A8CB-CFD3-494B-A848-FBB4830F2793_2023-06-25_21-10-31
    21:10:31.766 INFO : Start downloading...Vid Kbps
    21:10:31.859 WARN : Type: cbcs
    21:10:31.860 WARN : PSSH(WV): EhB/9FtPbJK+bOhjt/pmEEYFEhB/9FtPbJK+bOhjt/pmEEYFSPPGiZsG
    21:10:31.861 WARN : KID: 7ff45b4f6c92be6ce863b7fa66104605
    21:10:31.862 WARN : Reading media info...
    21:10:31.881 INFO : NaN: Video, h264 (avc1), 1280x544
    21:10:41.134 INFO : Binary merging...
    21:10:41.211 INFO : Decrypting...
    21:10:41.213 INFO : Done
  23. Banned
    Apr 2022
    Hong Kong
    @iamghost
    Didn't know non-premium users could watch the 720p video.
    I only met the window which let me resubscribe to their plans.
  24. Originally Posted by CrymanChen View Post
    @iamghost
    U are right. Non- premium users can't watch the vip video.
    Still waiting for your help
