I use a raw .265 (see attachment) and when I try to mux it into an mkv using ffmpeg
and:Code:ffmpeg version N-111058-g1359d6d5b2-g024c30aa3b+1 Copyright (c) 2000-2023 the FFmpeg developers built with gcc 13.1.0 (Rev6, Built by MSYS2 project) configuration: --pkg-config=pkgconf --cc='ccache gcc' --cxx='ccache g++' --ld='ccache g++' --extra-cxxflags=-fpermissive --extra-cflags=-Wno-int-conversion --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-librav1e --enable-libsrt --enable-libgsm --enable-libvmaf --enable-libsvtav1 --enable-mbedtls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads
I get:Code:ffmpeg -y -r 25/1 -i "G:\Output\2023-06-15@17_38_22_5310_01.265" -vcodec copy -map 0:0 -bsf:v hevc_mp4toannexb -tag:v hvc1 -aspect 640:352 -r 25/1 "G:\Output\test_new.mkv"
same for a simple:Code:Input #0, hevc, from 'G:\Output\2023-06-15@17_38_22_5310_01.265': Duration: N/A, bitrate: N/A Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt470bg/unknown/unknown), 640x352 [SAR 1:1 DAR 20:11], 25 fps, 25 tbr, 1200k tbn [vost#0:0/copy @ 000001707f002cc0] Overriding aspect ratio with stream copy may produce invalid files Output #0, matroska, to 'G:\Output\test_new.mkv': Metadata: encoder : Lavf60.6.100 Stream #0:0: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt470bg/unknown/unknown), 640x352 [SAR 1:1 DAR 20:11], q=2-31, 25 fps, 25 tbr, 1k tbn Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help [matroska @ 000001707ef2a7c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [matroska @ 000001707ef2a7c0] Can't write packet with unknown timestamp [vost#0:0/copy @ 000001707f002cc0] Error submitting a packet to the muxer: Invalid argument [out#0/matroska @ 000001707ef26400] Error muxing a packet [out#0/matroska @ 000001707ef26400] video:20kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown frame= 1 fps=0.0 q=-1.0 Lsize= 1kB time=00:00:00.28 bitrate= 18.0kbits/s speed= 481x!
adding ' -fflags +genpts':Code:ffmpeg -y -i "G:\Output\2023-06-15@17_38_22_5310_01.265" -vcodec copy "G:\Output\test_new.mkv"
fails too.Code:ffmpeg -y -r 25/1 -fflags +genpts -i "G:\Output\2023-06-15@17_38_22_5310_01.265" -vcodec copy -map 0:0 -bsf:v hevc_mp4toannexb -tag:v hvc1 -aspect 640:352 -r 25/1 "G:\Output\test_new.mkv"
Does anyone know how to do this with a current ffmpeg build?
Cu Selur
using
seems to work, but it someone knows an 'easier' command line to do this please let me know.Code:-bsf:v hevc_mp4toannexb,"setts=pts=N/TB*1/25:dts=N/TB*1/25"
Properly muxing Magix Vegas rendered raw AVC stream?
By lpmaskman in forum Video ConversionReplies: 4Last Post: 10th Feb 2022, 13:50 -
Why is Muxing necessary if I can just convert an MKV file to MP4?
By SilentPlanet in forum Newbie / General discussionsReplies: 23Last Post: 21st Sep 2021, 01:02 -
Why does muxing a video stream into a MKV file change that stream?
By 4L7zHhiyQO3Thui6 in forum Video ConversionReplies: 14Last Post: 11th Mar 2021, 04:45 -
FFMPEG HEVC/H.265 settings help
By kevindd992002 in forum Video ConversionReplies: 4Last Post: 31st Dec 2019, 22:40 -
how to extract lossless audio from an MKV file - ffmpeg fails
By batemanj in forum Newbie / General discussionsReplies: 2Last Post: 17th Apr 2019, 08:50
