  1. There are times when I need to upload an mp4 from Android smartphone to a cloud server and share it, or use Signal to send the mp4 to another Signal user.
    So I want to trim the mp4 to just the important part to minimize its size.
    I would like to do this losslessly.
    Is there an Android app that forum users feel they could recommend for this purpose ?
    On Windows desktop I use Lossless Cut. Is there something like it for Android ?
    TIA
  2. Google Play Store has one. "Lossless Video Cutter"
    It may have a video length issue as one poster gave a bad review for videos over 8 minutes long.
    Extraordinary claims require extraordinary evidence -Carl Sagan
  3. Thank you.
    I will give it a try.
    Most of what I want to share or send is shorter than that anyway.
    Any additional recommendations ?
  4. I have tried Lossless Video Cutter for Android.
    It does work.
    The only downsides so far...
    The ads are really intrusive - Tik Tok BLASTING AT TOP VOLUME TO YOU.
    There does not seem to be a way to specify a different output folder.
    The author so far has not responded to my email asking if there is a paid version or other way to avoid the above problems.
