Hello all.
I have an old animated film that im trying to cleanup, I have it looking pretty good all things considered. Im using vapoursynth via Hybrid to do it (for ease of testing, im not scared to only use VS).
I have a situation where different scenes need different tweaks to not look awful (compression artifacts/banding, etc etc), and im wondering what the best course of action would be for this?
Should I chop up the video into different sections (losslessly) and fix them up, then concat everything, or is there some way to using VS on only a part of the video?
Problem im thinking is if I cut up the video, I could have syncing issues from cutting.
Or maybe there is something im missing that I could do, im no expert. If anyone has any suggestions, please let me know!
I assume VS is similar to AVS: you can trim the input video into segments, filter each segment differently, then join the segments back together at the end. In AviSynth it would look something like:
Code:source = WhateverSource("filename.ext) # get source video part1 = Trim(source, 0, 1000).FilterSequence1() # break it into sections, part1 is frames 0 to 1000 and it's filtered in one way part2 = Trim(source, 1001,2000).FilterSequence2() # part2 is frames 1001 to 2000 and it's filtered in a different way part3 = Trim(source, 2001, 0).FilterSequence3() # part3 is frames 2001 to the end and it's filtered a third way part1++part2++part3 # part1 part2 and part3 are joined back togetherLast edited by jagabo; 15th Jun 2023 at 08:18. Reason: Fixed a bug in the sample script
and if you experience troubles with the audio (rarely happens, even with AlignedSplice ++) dub the original audio to filtered video (if you do not add/delete frames in the filtering)
Code:source = WhateverSource("filename.ext) # get source video part1 = Trim(0, 1000).FilterSequence1() # break it into sections, part1 is frames 0 to 1000 and it's filtered in one way part2 = Trim(1001,2000).FilterSequence2() # part2 is frames 1001 to 2000 and it's filtered in a different way part3 = Trim(2001, 0).FilterSequence3() # part3 is frames 2001 to the end and it's filtered a third way video_filtered=part1++part2++part3 # use audio from original clip audio=source video_filtered_audio=audioDub(video_filtered,audio) return(video_filtered_audio) -
You could:
- enable "Filtering->Vapoursynth->Misc->UI->Show 'Apply only to'-controls". These controls, appear behind each filter that supports them, allow applying a filter only to a range of frames. (Hybrid does not allow this for each filter, cropping, resizing, letterbox, deinterlacing, frame rate changes can only be applied for the whole clip.)
- enable "Filtering->Vapoursynth->Filter Order/Queue->Use Filter Queue". This way, Hybrid can use a filter multiple times. Note that each filter needs to be added to the filter queue (there are now +/- controls for each filter, to add or remove a specific filter setting from the queue)
Alternatively, you can write your own script in Vapoursynth/Avisynth and use it as source for Hybrid.
Hybrid has a bunch of options for Vapoursynth which are disabled by default, to keep it a bit more approachable for users.
*gig*
(No, Hybrid is not meant to be 'easy click and be happy' since there are too many options for that. If you want it simple, you need to simplify.)
Cu Selur
Ps.: Hybrid does not offer something similar for Avisynth, if you want to use Avisynth, you are best off writing the script on your own. (I even would recommend, then to not use Hybrid at all, but also write the encoding part on your own, since, for me, using Hybrid - or any other gui - just seems bothersome in that cast.)
PPs.: Splitting the source into multiple scene can also make sense depending on what you are doing, since sometimes one-script-to-rule-them-all might work, but can get really complex, and it might get hard to get an overview.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
It could be done without trimming, just using conditioning function what to do with particular n-th frame. Module animate does that.
those frame regions could overlap, filters could be chained, also filters could be applied on a region within a frame only, check manualCode:import animate def filter1(clip,*args): return clip.std.BoxBlur() def filter2(clip, *args): return clip.std.Expr(['x 50 -','','']) def filter3(clip, *args): return clip.std.Expr(['x 50 +','','']) clip = core.lsmas.LibavSMASHSource('source.mp4') MAP = [ (300, 400), [filter1], (401, 600), [filter1, filter2], (0, 1000), [filter3] ] clip = animate.run(clip, MAP) clip.set_output() -
Thanks for all the great replies!
I think I have an idea on what to do now, I will test them out once I have some free time.
Rename single file in a directory based on the content of a txt file
By D.LUFFY in forum ProgrammingReplies: 3Last Post: 7th Jun 2023, 13:16 -
Displaying multiple USB video microscopes on single monitor…
By Chale44incolo in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2023, 10:22 -
Burn multiple .mkv files to a single BD25?
By stonesfan187 in forum Newbie / General discussionsReplies: 5Last Post: 16th Dec 2022, 00:14 -
How to overlay multiple animations onto a single background?
By Mugunga in forum Video ConversionReplies: 6Last Post: 2nd Nov 2021, 02:00 -
Multiple vtt's to single srt
By qaqaqaq in forum SubtitleReplies: 3Last Post: 15th Sep 2019, 01:50
