    Aug 2008
    Canada
    Hi,
    I ran the AVSInfo Tool on my AVISynth+ 32-bit plugins folder. It did find a number of duplicate functions scattered across all the AVSI files. So I have some housekeeping to do.
    However, below the duplicates section in the AVSInfo Tool, I'm seeing 200+ rows of this:
    __________________________________________________ ______________________________
    LoadPlugin: プラグイン初期化エラー
    As you can see, there is no mention of the plugin/script at fault in the output. Also, whenever I try to bring up a 32-bit AVS script via AVSPMod32 and display the video, the same LoadPlugin error appears in the video window. FYI, the 64-bit side of AVISynth is fine.
    Has anyone ever run into this? Is there a way to fix it short of me rebuilding my plugins folder?
    Aug 2008
    Canada
    Originally Posted by VoodooFX View Post
    Share whole report.
    Sure thing. See attached.
    AvisynthInfo32.txt
    Aug 2008
    Canada
    OK, I installed Avisynth+ v3.7.2, but it didn't make any difference. I've attached the log again.
  4. Video Damager VoodooFX's Avatar
    Oct 2021
    At Doom9
    Move all plugins elsewhere and check if it works, then copy back plugins in parts to detect which one is the cause.
    Start with two parts, with start letters a-m and n-z then narrow down.
    Aug 2008
    Canada
    Yeah, I suspected that was going to be the only way to troubleshoot it. I was just curious if anyone had ever had the same issue here and if there was a quicker solution.
    I moved all the 32-bit plugins to another folder and tried it. No more error. Looks like something got corrupted somehow.
    Thanks for your help!
