Hi,
Needs deinterlancing help for documentary. Couldn't sure about deinterlancing this kind source.
Megui shown like this:
sample:
https://mega.nz/file/PBtkUaiB#zhLsM7a-zgsnuF3mtSVFejNVPifeqHgHJiL5PkVuS8Q
To retain smoothness of motion you should encode 60p, not 30p. I'm not sure what MeGUI calls it, maybe Yadif 2x, or Yadif Bob. Sometimes better than Yadif is BWDIFF. Much better is QTGMC(). I don't know if MeGUI supports them directly. If you build your own scripts you can use them.
That sample is actually 29.97p content . I would check other sections, if they are the same, then don't deinterlace, just treat it as progressive
29.970 to 25fps
By magnu in forum Video ConversionReplies: 17Last Post: 23rd May 2022, 03:50 -
QTGMC mov 29.970 (Constant fps) Ends up 58.42 FPS rather than 59.940
By VidNew23 in forum Video ConversionReplies: 9Last Post: 8th Apr 2021, 00:21 -
59.940 fps deinterlacing
By max_cady in forum Newbie / General discussionsReplies: 4Last Post: 1st Feb 2021, 14:35 -
Hybrid: QTGMC deinterlacing 29.97 gives me 600 fps
By bigass in forum Video ConversionReplies: 24Last Post: 22nd Oct 2020, 19:32 -
How to make 1080i 59.940 FPS video to 29.970 FPS
By Joycon in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2018, 14:47
