Results 1 to 11 of 11
    Nov 2014
    Germany
    Hi folks!
    I could extract following links from a video from vimeo,here the extracted links:
    "https://f.vimeocdn.com","vimeo_api_url":"api.vimeo.com","r equest":{"files":{"dash":
    How can I catch these?
    Any help was great!!!
    Greetings,
    ghostrewel
  2. If you've the URL to the video on Vimeo, use
    yt-dlp URL
  3. Image
    [Attachment 71674 - Click to enlarge]
    import requests
    import json
    import re
    print('test link: https://neilyoungarchives.com/movietone/833850675\n')
    link = input('link: ')
    link_id = re.findall(r'neilyoungarchives.com/.*/(.*)', link)[0].strip()
    headers = {
        'Connection': 'keep-alive',
        'Referer': 'https://neilyoungarchives.com/',
        'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36',
    params = {
        'autoplay': '0',
        'controls': '0"',
    response = requests.get('https://player.vimeo.com/video/'+link_id+'', params=params, headers=headers).text
    get_json = re.findall(r'<script>window.playerConfig = ({.*)<\/script>', response)[0].strip()
    js_obj = json.loads(get_json)
    video_title = js_obj['video']['title']
    print(f'\ntitle:\n{video_title}\n')
    m3u8_url = js_obj['request']['files']['hls']['cdns']['akfire_interconnect_quic']['url']
    print(f'm3u8:\n{m3u8_url}')
    Nov 2014
    Germany
    M3u8 is Forbidden,another way to download the video?
  5. works for me - normally and with a german vpn
    Nov 2014
    Germany
    Which program and command
    you using?Forbidden HTTP Error 403 is the result...
  7. Anonymous9875434
    Guest
    https://56vod-adaptive.akamaized.net/exp=1686663635~acl=%2Ff89538de-ae34-4f36-a2f7-a0f...026f588db93bbb 37347cc24d471088c417bba2ee2d3962042702/f89538de-ae34-4f36-a2f7-a0f59dcd8eb7/sep/video/124c01a4,3f4d38cb,5b5f7549/audio/80bc1494,b269f417,da7d77db/master.mpd?base64_init=1&query_string_ranges =1
    you need to decode the unicode '\u0026' back to '&' and it should download fine.
    and master.json to master.mpd
    with a fresh link
  8. Originally Posted by ghostrewel View Post
    no problem
    [Attachment 71679 - Click to enlarge]
    import requests
    import subprocess
    import json
    import re
    m3u8DL_RE = 'N_m3u8DL-RE.exe'
    headers = {
    params = {
        'autoplay': '0',
        'controls': '0"',
    print(f'\n{video_title}\n')
    print()
    subprocess.run([m3u8DL_RE,
                    '-M', 'format=mkv:muxer=ffmpeg',
                    '--del-after-done',
                    '--concurrent-download',
                    '--auto-select',
                    '--log-level', 'INFO',
                    '--save-name', video_title,
                    m3u8_url])
    Nov 2014
    Germany
    Thank you all for the help!
    I could save the video now!!
