I have video that i am trying to stabilize to test Deshaker, however after spending lots of time and different settings i am still have jello effect on building on the right
Perhaps someone with more Deshaker experience than me can give an advice?
I found that using VirtualDub's "Unsharpen Mask" filter before processing with VirtualDub gets better detection.
My advice is don't use deshaker
Recent versions of Mercalli, or Adobe Warp Stabilizer have better Rolling shutter compensation , and Adobe has a dedicated Rolling Shutter compensation filter. Deshaker is not very good with RS artifacts such as jello, skew
None of them are "perfect" for RS artifacts . The underlying problem is your camera and it's CMOS sensor . A global shutter would eliminate the problem or one with a faster scan rate would reduce the issue -
I didn't realize you had already posted when I got your PM.
Poisondeathray is correct: Deshaker has only a very crude rolling shutter correction capability. Fixing rolling shutter artifacts is quite different than correcting camera movement, but since camera movement is one of several situations where a rolling shutter creates weird artifacts, rolling shutter correction is sometimes found in stabilization programs.
I am not sure whether Mercalli and other stabilization programs which contain rolling shutter features will correct for ALL rolling shutter artifacts, like bent propeller blades, but they usually do a pretty good job getting rid of poles which lean over when the camera pans, and wobble from vibration.
VirtualDub filters: Film Dirt Cleaner, Intelligent Brightness, deshaker(?)
By calmkeeper in forum RestorationReplies: 2Last Post: 23rd Feb 2022, 17:21 -
Text output pf deshaker filter?
By jumpjack in forum EditingReplies: 1Last Post: 8th Aug 2021, 10:14 -
video converter any video converter has basic settings video bit rate as -1
By jraju in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2020, 12:15 -
Deshaker and slow virtualdub script
By Sheik in forum Video ConversionReplies: 1Last Post: 7th Aug 2019, 05:24 -
DeShaker use
By Tafflad in forum Newbie / General discussionsReplies: 55Last Post: 15th Mar 2019, 06:06
