I have a Pioneer Blu-Ray writer BDR-207EBK installed in my Windows 10 PC. I hardly use it these days but I wanted to check a family DVD that I created few years ago (finalized) but the player doesn't recognize it. I tried to uninstall it, restart the PC but still doesn't work, although device manager shows it is working properly.
I checked my DVD on a portable Samsung DVD player that works by connecting it to USB connector and it plays perfectly.
Any idea what can be the reason and if there is a chance to bring it to life again?
Check another DVD, then a CD and a Blu-ray. It is possible that only one type of reading is broken. Try commercial discs of each type to rule out compatibility issues with a specific selfmade DVD.
Still no luck with getting the Blu Ray drive to open any DVD.
I tried all the suggetions I could find but nothing helps.
I suspect that Windows 10 Pro is the culprit and I am going to try and renistall it when I have the time.
In the meantime, I ordered a SATA to USB adapter that can work with DVD players. At least it will tell me if the drive is faulty and needs replacement. -
Did you try using a can of compressed air to blow out the dust inside the drive? Did you try checking the driver's SATA power and data connections for oxidation?
I uninstalled the driver for my Blu-ray writer, how to re-install it?
By Vidint in forum DVD & Blu-ray WritersReplies: 20Last Post: 24th Dec 2022, 17:58 -
Visio Blu Ray player vbr120 unable to read Blu ray discs
By juntjoo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 14th Sep 2020, 12:02 -
Montblanc Hack not working with U.S. purchased LG UBK90 Blu-Ray Player
By Sparky 713 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 6th Jun 2020, 16:04 -
LG blu ray writer and verbatim BD-R
By mickmars in forum DVD & Blu-ray WritersReplies: 12Last Post: 9th May 2020, 20:45 -
Blu Ray blank disc issue - disc or writer?
By Damirko1981 in forum MediaReplies: 1Last Post: 10th Oct 2019, 13:44
